Forum: FPGA, VHDL & Verilog Unexpected Synthesized bit order in Quartus with SystemVerilog
von Joshua V. (Company: Harvey Mudd College) (poofjunior)
Hi everyone,
I was under the impression that the bit-order of values in SystemVerilog
was left-to-right: MSbit-to-LSbit.
Recently, I wrote up a 11-bit-wide multiplexer:
module test_mux( input logic [10:0] input_a,
                 input logic  override,
               output logic [10:0] output_c);
parameter [10:0] constant = 11'h00F;
    assign output_c = (override) ?
                        constant :
                        input_a;
endmodule
expecting the more-significant bits to be zeros and the last four
less-significant bits to be ones. When I synthesized it and visualized
the result, though, I got the unexpected constant 11'h780 as my constant
input.
I tried an alternative:
always_comb
begin
    integer i;
    for (i = 0; i < 11; i = i + 1)
    begin
    output_c[i] = (override) ?
                       constant[i] :
                       input_a[i];
    end
end
and got the expected constant input to be 11'hf.
(a) Are the two above code snippets not the same??
(b) What is the expected bit-order in Quartus?
I'm ruling out that the RTL viewer is just rendering the values
incorrectly. To do so, for the unexpected result, I expanded the mux
input and saw that mux[0]: 1, mux[1]: 1 ... mux[10]:0, which would rule
out that Quartus' RTL viewer is just rendering the result incorrectly.
Thanks for taking a look, and I'd appreciate any leads on this!
Cheers!
: Edited by User
von Lattice User (Guest)
It looks like a bug in Quartus, but this may be only in rendering the
RTL view. Does Quartus also have a technology view?
(I have testet it with Synplify Pro (Lattice) and it worksn as
expected.)
Quartus does have a technology view, but from the looks of it I think
the constant input is embedded in the logic cell without giving me any
hints as to what value it's storing.
Thanks for the tip! I'll see if the folks at Altera have some more tips.
(I'm using Quartus 15.0 right now.)
There is an hint.
If you look closely, bits 0-3 are using the input DATAB on the logic
cell, the others are using DATAD. So my guess it is a bug in the RTL
View.
Wrong synthesis result would be a killer bug.
