Hello, my Verilpg code: module top (input a, b, output D1); reg a = 1; reg b = 1; integer y; assign y = a & b; if (y == 1) assign D1 = 1; else ; endmodule To explain this: I want to see, if y = 1 or true (it should get true/1 because a and b are 1 so the logic tile sends an 1) the LED should light. But I' bad in programing Verilog so please just help me learning. Maybe the y need to be an in/output? All help is welcome. I'm working with icestorm tools and can't even generate the .blif file. Error: ERROR: Condition for generate if at program1.v:10 is not constant! Thanks for help.
Verilog wrote: > assign D1 = 1; I have no idea how the verilog syntax works, but it seems curious that you assign an integer. It should probably be something like "1'b1" And by the way, you're having a weird coding style. What you want to write is one line. If you are writing more you're doing wrong. I would guess: assign D1 = a & b I also doubt you can assign a value to an input. Especially an integer.
