Forum: FPGA, VHDL & Verilog How to interact with Lattice FPGA
Author: Banane (Guest)
Hello,
I've bought a lattice icestick (http://www.latticesemi.com/icestick) and
programmed it with iceprog (http://www.clifford.at/icestorm/) with the
following verilog code:
example.v:
module top (input a, b, output y);
  assign y = a & b;
endmodule
example.pcf:
set_io a 1
set_io b 10
set_io y 11
All works great, but I don't know how to interact with this small
circiut on my FPGA. How can I (for example) send a 1 for the a-input and
another 1 to the b-input and then getting a 1 from the FPGA back. Do I
need a special program for this or something like that?
Thank you for your support.
Sincerely,
Banane
: Locked by Moderator
Author: Sebastian (Guest)
It seems that a connector can be soldered to the stick, the pin numbers
probably correspond to pin numbers on the FPGA. This way, signals can be
routed to external circuitry.
First of all, thank you for your fast response.
I am searching for a software solution for this problem.
Do you know anything?
Author: Lattice User (Guest)
There isn't a software solution to interact with your circuit.
The board has 5 LEDs, try to get one of them flashing, the "Hello World"
for FPGAs.
Author: Bello (Guest)
Author: Antti Lukats (xilant)
there is no jtag on icestick
Do you know a solution for my problem?
To go into detail: I would like to set a and b manually ( 1 or 0 ) and
then see the result on y (in terminal/ on a program or something).
First, I only need one Logic Tile, only one LUT4 of the FPGA but it is
hard to understand the documentation of the icestorm project because I
only want to work with digital IN and OUT puts and not with LEDs/clock
or something.
Author: P. K. (pek)
Banane wrote:
> I only want to work with digital IN and OUT puts and not with LEDs/clock
> or something.
> for FPGAs.
@Banane:
The "Hello world" is the easiest way to get started with the system (you
don't need to drive any inputs, and you can observe the result without
need of scope or multimeter). If you mastered the tool chain, flash
programming etc., there is still plenty of time to start with external
inputs and not-so-easy-to-observe outputs and later make your results
visible on a PC (that's still somewhat further away...).
Divide (into simple steps) and conquer is the way to do it.
: Edited by User
Seems he did that up to some level.
As Banane wrote:
> boutght a lattice icestick ... and programmed it ...
> All works great
But one thread is enough.
Go further on tere: https://embdev.net/topic/375560
: Edited by Moderator
This topic is locked and can not be replied to.
