Forum: FPGA, VHDL & Verilog Scaling to a 12-bit ADC value
von Wil (Guest)
Hello,
I want to scale a current value(Icurr) (in Amperes) to a corresponding
12 bit value. The to-be scaled  current value(Icurr) and a 12-bit ADC
value(Iact) are given as inputs to a PID controller as actual(Iact) and
expected(Icurr) values.
I am not sure how to approach the scaling.
My idea of approach is to : For example take a 1V=4A value as an input
to ADC and find the corresponding 12bit value. Take it as reference to
scale Icurr accordingly. But I am also not familiar reading from a ADC
data sheet to find the approximate 12bit value for an input
voltage/current.
Any suggestions?
First question:
Is your question related to FPGA, Verilog or VHDL?
If so: how?
Wil wrote:
> Any suggestions?
What hardware?
> But I am also not familiar reading from a ADC data sheet to find the
> approximate 12bit value for an input voltage/current.
What ADC?
So you have a "device" that forms 1V out of 4A, meaning 2A result in
0.5V?
von Schlumpf (Guest)
typical:
Vin = Vref : Out = xFFF
Vin = 0    : Out = x000
Vin = Rshunt * I
Out = Vin * (xFFF / Vref)
But the slope of this calculation is 1/4096 wrong.
But you can ignore the deviation if you want...  ;-)
For a 12 bit ADC this formula is correct: Out = Vin * (x1000 / Vref)
: Edited by Moderator
right :-)
von Wil (Guest)
Lothar M. wrote:
> First question:
> If so: how?
Yes, I want to implement the scaling in VHDL
> Wil wrote:
>> Any suggestions?
> What hardware?
Altera Cyclone IV
> What ADC?
LTC1407 12bit ADC
> 0.5V?
Yes, A Dual Op_Amp gives out 1V=6A (seeing from the layout)
von Wil (Guest)
Schlumpf wrote:
> typical:
> Vin = Rshunt * I
So here to get a 12 bit value, Should I just consider Vin=1V
(irrespective out of the 4A i.e. 1v=4A ?).
Or do I need to calculat the correspoding voltage for 4A? (V= 4*Rshunt)
How do I find Rshunt from the datasheet?
The datasheet for LTC1407 says Vref=2.5V.
So for Vin=1 Out should be 1638.
Because at Imax you want full scale inputof 2.5V  for the ADC you have
to calculate Rshunt = Imax/2.5V
Buuuuuut(!):
This will only work if you can accept 2.5V voltage voltage drop over
your shunt...
