Forum: FPGA, VHDL & Verilog SPI slave open core simulation diagram
Author: puka1012 (Guest)
Hi all,
If someone has tried the spi slave implementation from open
cores.org,can you please post siumlation diagram with little
explanation.However,this code doesnt seem to be a simple spi slave
implementation as it has too many inputs and output ports and most of
the signals are unknown.I am uploading the code for the quick
reference.If someone has time,please run it in the modelsim and let me
know
: Moved by Moderator
puka1012 wrote:
> the spi slave implementation from open cores.org
I had finished reading the code after those 2 lines:
use ieee.numeric_std.all;
use ieee.std_logic_unsigned.all;
Its obviously a beginners code. That can be easily seen throughout the
code at such things:
- a "double-clocked" process
- the sensitivity list has too much signals in it
    in_transfer_proc: process (clk_i, wren_i, wr_ack_reg) is -- clk_i is enough here!
    begin
        if clk_i'event and clk_i = '1' then     -- a clock!
        end  if;
        if clk_i'event and clk_i = '1' then     -- and once more a clock? :-o
        end  if;
    end process in_transfer_proc;
And this: a clocked process which has also a async part. Wow!
    out_transfer_proc : process ( clk_i, do_transfer_reg, di_req_reg,
                                  do_valid_A, do_valid_B, do_valid_D,
                                  di_req_o_A, di_req_o_B, di_req_o_D) is
    begin
        -- CLOCKED !!!
        end if;
        -- COMBINATORIAL !!!
        do_valid_next <= do_valid_A and do_valid_B and not do_valid_D;
        di_req_o_next <= di_req_o_A and di_req_o_B and not di_req_o_D;
    end process out_transfer_proc;
Its easy to implement a thoroughly synchronous(!!) SPI slave interface
in less then 100 lines of code. See the
Beitrag "Re: Erfahrung mit SPI Slave und Spartan 6 FPGA?" (try google
translator)...
: Edited by Moderator
Author: Susa Kl (suhas_s)
Can you please tell me what is PREFETCH and prefetch look cycle and its
implementation in the code??...I know there are simple ways to implement
it but i really want to understand this
: Edited by User
Have a look at the code: that "PREFETCH" its a wrong name for "i have
nearly transmitted all of the bytes". That is signalled to the "outer
world" with the di_req_o port. That signal is generated form the
di_req_next with a very obscure sync stage and a 5 bit shift-register
in between...
  • [vhdl]VHDL code[/vhdl]
