Forum: FPGA, VHDL & Verilog FPGA for Evolvable Hardware Implementation
Author: Dude (Guest)
Hello,
which FPGA device is suitable for working on the topic evolvable
hardware?
I'm planning to use this method:
1. Generate random Bitstream
2. Load Bitstream to FPGA
3. Fitness-Test
4. Modify Bitstream via Genetic/Evolotuinary Algorithm
5. Go to Step 2.
[Until perfect solution is found]
I already bought a Xilinx Ml310 Development Board as shown here:
http://www.xilinx.com/products/boards/ml310/current/
Unfortunately I've come to the conclusion that this device might not be
a good way to start this project, because I can't find much information
about bitstream-manipulation from Xilinx-FPGAs in general (I've found
the tool JBits, but I can't find useful documentation nor the SDK
itself). Also
In the end I want to reproduce experiments like this from Dr. Adrian
Thompson with his tone discriminator:
http://archive.bcs.org/bulletin/jan98/leading.htm
Can anyone give me some advice on which device I should buy and which
lectures I should read before I start this project?
I would prefer a chip which is easy in handling the bitstream
manipulation, because that's what is the evolutionary process is all
about.
Thank you for your support and sorry for my bad english :)
Sincerely,
Dude
Author: Antti Lukats (xilant)
Hi Dangerous ground!
Xilinx FPGAs can modify itself on the fly, but you need non-free license
to the "partial reconfig" solution.
if you want something OPEN SOURCE, then
IceStorm has fully documented bitstream and tools for ice40
https://hackaday.io/project/6636-iced-an-arduino-s...
I just now tested my first real FPGA design that was implemented using
icestorm toolchain
ICE FPGA can not directly manipulate itself at LIVE, but it could
reflash one of the multiboot images and restart itself
Hello Antti Lukats,
First, thank you for your fast response :)
The site from IceStorm is very interesting.
Where can I buy this board and how much does it cost?
How long does a reflash take?
Sincerely,
Dude
Author: Michael Engel (Guest)
About 20 years ago, Adrian Thompson (University of Sussex) did some
interesting work in this area on (completely obsolete and no longer
available) Xilinx 6216 FPGAs. For example, he evolved a circuit that was
capable of distinguishing two different frequencies:
http://www.damninteresting.com/on-the-origin-of-circuits/
http://citeseerx.ist.psu.edu/viewdoc/download?doi=...
Unfortunately, if I remember correctly, the evolved circuits turned out
to include physical characteristics of the specific FPGA the GA was
running on, such as propagation delays, which is probably not what you
intended. Nevertheless I thought this link might be interesting.
Back then, the internal structure of the 62xx FPGAs and the bitfile
format was well documented (the design was acquired by Xilinx in a
company take-over) and people were able to write their own synthesis
tools without the need to reverse engineer anything...
Argh, somehow managed to overlook that you mentioned Adrian's work in
your post. Oops.
I'm really into Antti Lukats idea.
Can anyone tell me the fpga with the highest number of logic cells that
can be programmed with the IceStorm Tools?
I've already found this one:
http://www.latticestore.com/searchresults/tabid/46...
But I wounder if there is any bigger FPGA whith more logic cells?
Sincerely,
Dude
current status of icestorm
supported devices HX1K, HX8K (very likely also LP1K and LP8K) the 8K
devices are the largest ICE devices.
if you want LARGE reprogrammable GRID, then one option could be
stuffing a lots of DIPSY style board in connected grid
https://hackaday.io/project/6592-dipsy
the FPGA there is very low cost and low power, so a even a rather large
array would still be moderate in price.
unfortunatly the UL1K is not yet supported by icestorm tools :(
icestorm includes download tool to configure the ice, the protocol is
very simple.
SPI slave mode config is also supported, so if you want to have array
that can be reconfigured fast, I would use some Xilinx ARTIX with lots
of IO to spit out a lot of SPI masters that each will configure ICE
devices.
Author: britzl (Guest)
> 3. Fitness-Test
> 5. Go to Step 2.
But for complex circuits and larger FPGAs this will take a very long
time, no?
OK for ultra small 1k LUT FPGA it may work - but for "normal" size
FPGAs?
  • [vhdl]VHDL code[/vhdl]
