Forum: FPGA, VHDL & Verilog Reversing bits
Author: puka1012 (Guest)
Ich habe eine hexadecimal addresse ABCD1234.Wie kann ich es reverse
bekommen.Configuration website von ethernet zeigt 0x3412CDAB(Die werte
von diese hexadecimal addresse wird von miso auf signal tap
gelesen)aber,webseite muss genauso wie ABCD1234 zeigen.Wie kann ich es
machen(Besser wäre wenn jemanden auf englisch erklärt)
: Moved by Moderator
Author: Max D. (max_d)
What programming language ?
Genral idea: Write into array in one direction, read from it in the
other direction....
VHDL
You generate a website with VHDL ?
Maybe give some further explanation how the data is transfered from the
SPI-Interface (judging from the signal-name miso) to the website...
i dont generate website with vhdl.Instead i have a embedded system board
with FPGA in it to which transfer takes place.However,there is a website
of the entire board(ethernet)(It has even microcontroller and like i
said,FPGA as well)...From the website FPGA is triggered and we get the
hexadecimal address
Author: .. (Guest)
> other direction....
;-) das ist eine gute idee!
auf sowas einfaches bin ich noch gar nicht gekommen ;-)
und werde es zukünftig so machen bei MSB / LSB
txs
>> other direction....
> txs
Danke für die Lorbeeren :)
Is halt der übliche deal Speicher gegen Laufzeit
> said,FPGA as well)
I have very little knowledge of VHDL (and programmable logic in
general), therefore my approach would be to do the adjustment inside the
µC on the Board. The way the data looks suggests to me, that the
endianess of the two SPI-Devices doesn't match...
Author: Gerald M. (gerald_m17)
You just have to swap byte 1 and 2, and byte 3 and 4. Then you have to
swap the to words.
How you do this depends on how you store the data (eg std_logic_vector,
signed, integer...)
Author: Achim S. (Guest)
   function swapbytes(din:std_logic_vector(31 downto 0)) return std_logic_vector is
   begin
      return din(7 downto 0) & din(15 downto 8) & din(23 downto 16) & din(31 downto 24);
   end function;
Author: P. K. (pek)
Blödsinn. Der Swap kostet Dich rein gar nichts. Die Drähte zwischen
Quelle (dort wo die Adresse herkommt) und Senke (dort wo die Adresse
benötigt wird) liegen einfach anders...
Achim S. schrieb:
> function swapbytes
Das kann man auch ganz ohne Funktion schreiben, wenn man es nur einmal
braucht...
... for English written posts:
https://embdev.net/forum/fpga-vhdl-verilog
This here is the German forum!
: Edited by Moderator
Author: Werktätiger (Guest)
-1 useful
You mean German-speaking ?! Or Germany's citizens?
Mit Gruß,
Author: Grmml (Guest)
Of course Lothar means German speaking. Here in the forum, everyone is
welcome.
I wrote "written" instead of "spoken", but my intention should be fairly
clear:
You can reside in any part of the world and speak any language. But
here (mikrocontroller.net) you should write German and there
(embdev.net) you should write English...
  • [vhdl]VHDL code[/vhdl]
