Forum: FPGA, VHDL & Verilog External oscillator on my LatticeXP2 Brevia2
von Neoz (Guest)
Hi !
(Sorry in advance for my english that is not very good)
I'm an apprentice in a French company and I have a project based on an
FPGA.
The new development board we bought for my tests has an external
oscillator of 50 MHz unlike the first one i used and started to program
on (Lattice MachXO2) that has one of 12 MHz.
My current problem is that I need a 1.5 MHz clock (I can't do with
something else) and 12 MHz was a multiple of this but not 50 ...
So, I tried to use an external oscillator of 36 Mhz: I linked it to one
of the I/Os. But all other I/Os are parasitized by this clock.
I checked the wiring and it seems good. The clock works normally.
My question : Is there a special I/O made to be a clock ? The actual
oscillator of 50 Mhz is on pin 21 of the FPGA. I put mine on pin 106.
Thanks !
von Lattice User (Guest)
What du you mean with "parasitized"?
Pin 106 is a GND Pin. So you missed something while checking.
There are actually pins which have a special funktion for clock input,
you should use one of them.
On the LFXP2-5E-5TN144C these are: 21,28,56,61,78,88,116,120
But why don't you use a PLL (the LFXP2-5E has two) do create a 12 MHz
clock from the onboard 50 MHz oscillator?
von Neoz (Guest)
There is lot of noise on input and output signals.
Yep sorry, it is on pin 116, not 106. So this is ok for the input.
I never tried to use this so I'll see how it works ;)
Thanks a lot!
von Neoz (Guest)
I attached a screenshot of my signals.
In blue : the good signal without noise.
In red : the signal I have with this new development board.
This looks bad, but i doubt it is caused by the development board
itself. (unless it is already damaged)
Check the Vccio (3.3V) with the scope. If you power your external
hardware from the development board, you possible may draw to much
current. Also keep in mind the limitations for USB power.
Recheck your wiring again, with emphasis on good ground connections. A
bad ground connection can cause all kinds of weird behavior.
Check if the signals from the FPGA are ok while nothing extrenal is
connected.
von Andreu (Guest)
Hi, I am also new to MACHXO2 FPGAs, IMHO CLK0, CLK1, and so on are
Lattice Diamond primitives. This worked for me:
module main
  input CLK0,
  output reg led,
        output enable_osc
  assign enable_osc = 1'b1;
  always @( posedge CLK0 ) // or CLK1, CLK2, etc...
  begin
    led <= ! led;
  end
endmodule
Notice that the external oscillator has a enable input that is connected
to pin 32 of the FPGA through a zero ohm resistor, you should either cut
that resistor(the oscillator have a pull-up resistor inside), or output
a high level to this pin.
: Edited by Moderator
