Forum: FPGA, VHDL & Verilog Digilent Ambient Light Sensor not working
von YS P. (Company: Company) (magictaro)
Hello
I'm using BASYS2 at Digilent Co.
and Studying Ambient Light Sensor Pmod.
I think below source code is correct, but not working on my board.
clk : 50Mhz
sclk : 1Mhz
cs : sclk x 16 count
data 8bit ( dout is 1bit data)
LED : output and check of information by Ambient Light Sensor
My source code is below.
but it's not working on BASYS2 board.
(I did and saw test bench simulator, but there is correct output pulse
LED etc)
I don't know what is error . So Please some imformation or advice
LIBRARY IEEE;
USE IEEE.std_logic_1164.ALL;
USE IEEE.std_logic_unsigned.ALL;
ENTITY SPI3 IS
PORT(
clk : IN std_logic;
clr : IN std_logic;
dout : IN std_logic;
led : OUT std_logic_vector( 7 DOWNTO 0 );
sclk : OUT std_logic;
cs : OUT std_logic
END SPI3;
ARCHITECTURE SPI3_be OF SPI3 IS
TYPE state_type IS( idle, adc_r, adc_w );
SIGNAL state : state_type := idle;
SIGNAL cnt_sclk : INTEGER RANGE 0 TO 49;
SIGNAL newsclk : std_logic := '0';
SIGNAL cnt_cs : INTEGER RANGE 0 TO 1599;
SIGNAL newcs : std_logic := '1';
SIGNAL data : std_logic_vector( 7 DOWNTO 0 );
SIGNAL cnt_data : INTEGER RANGE 1 TO 16;
BEGIN
sclk <= newsclk;
cs <= newcs;
clkdiv : PROCESS( clr, clk )
BEGIN
IF clr = '0' THEN
cnt_sclk <= 0;
cnt_cs <= 0;
newsclk <= '0';
newcs <= '1';
ELSIF clk'EVENT AND clk = '1' THEN
IF cnt_sclk = 49 THEN
newsclk <= NOT newsclk;
cnt_sclk <= 0;
ELSE
cnt_sclk <= cnt_sclk + 1;
END IF;
IF cnt_cs = 1599 THEN
newcs <= NOT newcs;
cnt_cs <= 0;
ELSE
cnt_cs <= cnt_cs + 1;
END IF;
END IF;
END PROCESS clkdiv;
FSM : PROCESS( clk, clr, state )
BEGIN
IF clr ='0' THEN
cnt_data <= 1;
data <= "11111111";
CASE state IS
WHEN idle =>
IF newcs = '1' THEN
state <= idle;
ELSIF newcs ='0' THEN
state <= adc_r;
END IF;
WHEN adc_r =>
IF cnt_data >0 AND cnt_data <4 THEN
cnt_data <= cnt_data + 1;
state <= adc_r;
ELSIF cnt_data > 3 AND cnt_data <12 THEN
data( 11 - cnt_data ) <= dout;
state <= adc_r;
ELSIF cnt_data > 11 AND cnt_data <16 THEN
state <= adc_r;
ELSIF cnt_data = 16 THEN
state <= adc_w;
END IF;
WHEN adc_w =>
led <= data;
cnt_data <= 1;
state <= idle;
END CASE;
END IF;
END PROCESS FSM;
END SPI3_BE;
