Hello. While I was studying the theory I have got that if you write a netlist, then you can generate a bitfile, load it into the FPGA and execute the program. I have done a double check with my Xilinx FPGA: -I created a VHDL program with Vivado -I defined the constraints (link inputs and outputs of my VHDL program to the actual pins of my FPGA) on a new file (.xdc) -I generated the bitfile, loaded it into the FPGA and tested the program (it worked) -Finally I exported the netlist (still with Vivado) generating the .edn file Next, to check if the theory was correct I have done: -I created a new post-synthesis project -I imported the netlist previously generated (without the constraint file) -I tried to generate the the bitfile but I got errors. I solved by creating the constraints (.xdc). So, my question is: is there the possibility to define the constraints into the netlist or every time I import a netlist should I have to create an external file in order to define the constraints? Thanks.
netlist is just a schematic without layout Information. Without constraints the place&route tool could place two elements with a Connection over the whole chip. for slow frequencies it works but for fast signals this Connection would have a too high capacitive load. So you need frequency information, among other things, in your constraint file it is possible in xilinx to give some constraints by attributes but imho the best way is to add a constraint file and avoid attributes
