Forum: FPGA, VHDL & Verilog Instantiating IOBUF in MHS file
von MarkusMSchmidt (Guest)
Dear FPGA colleagues,
please, for short ignore the fact that XPS is discontinued
implementation tool by Xilinx - I have to use it now.
Problem:
I remember having instatiated IOBUFS inside the top-level MHS-file of a
FPGA project. But I can't remeber how this was done. One way is to do
the following:
PORT i2c_sda_0_I = "", DIR = I
PORT i2c_sda_0_O = "", DIR = O
PORT i2c_sda_0_T = "", DIR = O
PORT i2c_sda_0 = "", DIR = IO, THREE_STATE = TRUE, TRI_I = i2c_sda_0_I,
TRI_O = i2c_sda_0_O, TRI_T = i2c_sda_0_T
where now i2c_sda_0 is the IO inout of the IOBUFFER.
Assume I have a signal "to_z_iobuf" that is constantly high and I want
it to put it onto the tri-state enable input T of the IOBUF such that
the FPGA pad is constantly on high impedance 'Z'.
Can I do:
BEGIN IOBUF
 PARAMETER INSTANCE = iobuf_inst01
 PORT I = proc_sys_reset_0_BUS_STRUCT_RESET
 PORT LMB_CLK = clk_120_0000MHz
END
Or am I completely wrong and there is no way to separately instantiate
them inside the MHS?
Cheers
Markus
