Hello. Normally, a user, writes the VHDL code and then he runs the synthesis in order to generate the netlist. I'm facing the opposite problem: with JHDL I have generated the netlist and once I import it in a new empty project on Vivado (I have Xilinx FPGA) I can not run the synthesis because Vivado tells me that I don't have any VHDL file in my project. Is possible starting from a netlist, create a HDL file? Well, I know that the netlist represents the interconnection of a specific HDL file (so I guess it is possible) but I don't understand how to link HDL and .edn files.
Junior H. wrote: > I can not run the synthesis You don't need to run synthesis, because the output of the synthesizer is a netlist...
Lothar M. wrote: > Junior H. wrote: >> I can not run the synthesis > You don't need to run synthesis, because the output of the synthesizer > is a netlist... In order to generate the bitfile using Vivado, I click on "Generate Bitstream" but it prints out this message: There are no implementation results available. OK to launch synthesis and implementation? 'Generate Bitstream' will automatically start when synthesis and implementation completes. It forces me to run the synthesis and then implementation. While it is running the synthesis it prints out the error:"Unable to run synthesis. No HDL sources found in project". Do you know any other tool to generate the bitfile from the netlist for Xilinx FPGA? My FGPA is Xilinx AC701 and they only officially provide Vivado suite.
I have been solving creating a post-synthesis project but now I get these 2 design errors: -[Place 30-494] The design is empty -[Common 17-69] Command failed: Placer could not place all instances Does anybody have idea why I get these errors? I just created a post-synthesis project importing the netlist. Vivado prints out that error while it is trying to generate the bitfile. Thanks
