Forum: µC & Digital Electronics RFduino and SparkFun CAN bus shield (MCP2515)
von fuesel (Guest)
Hi everyone
I am having real trouble with my RFduino/MCP2515 combination. I
originally tried the code with libraries on an Arduino Leonardo and it
worked after some tries. I tried to use the exact same code with my
RFduino, but it failed. I could see the data sent over SPI with my logic
analyser to the MCP2515 and it responding to the RFduino. I tested by
writing registers, then read it back and there is no problem at all. But
I cannot receive any CAN messages, in fact the flags in the RX status
are never set. I now try to use it in listen-only mode for debugging.
What bothers me is that I had a look on the SPI data exchange with my
logic analyser and it is slightly different: I send the same data, but
get back a lot of chatter with my Leonardo, but not with the RFduino.
(See attached pictures) Else I also used the same configuration data.
Just to be sure I recalculated the CNF3,2,1 data with the Microchip
Timing Calculator (and tried other settings). The only thing which is
different is the 3.3V supply from the RFduino vs the 5V from the
Leonardo. But the MCP2515 is rated down to 2.8V!
So in short:
MCP2515 works in terms of reading and writing registers and changing
mode
CAN reception works on my bike, but only with Leonardo.
Data
http://ww1.microchip.com/downloads/en/DeviceDoc/21801d.pdf
https://www.sparkfun.com/products/10039
If anybody has an idea what to try, I would be really grateful.
The code attached only depends on the SPI library, I wrote it to
eliminate any problems coming from the libraries I used.
#include <SPI.h>
#define CS SS
#define mcp_Reset 0xC0
#define mcp_WriteRegister 0x02
#define mcp_ReadRegister 0x03
#define mcp_CNF3 0x28
#define mcp_CNF2 0x29
#define mcp_CNF1 0x2A
#define mcp_BFPCTRL 0x0C
#define mcp_TXRTSCTRL 0x0D
#define mcp_RXB0CTRL 0x60
#define mcp_RXB1CTRL 0x70
#define mcp_CANCTRL 0x0F
#define mcp_CANSTAT 0x0E
#define mcp_CANINTE 0x2B
#define mcp_CANINTF 0x2C
#define mcp_RXSTATUS 0xB0
#define mcp_STATUS 0xA0
#define mcp_READRXB0SIDH 0x90
#define mcp_READRXB1SIDH 0x94
#define mcp_EFLG 0x2D
#define mcp_RXERRC 0x1D
#define mcp_MODE_NORMAL 0
#define mcp_MODE_LISTENONLY 3
#define mcp_MODE_CONFIG 4
30
31
#define set_CNF3 0x02 //0x02
32
#define set_CNF2 0x90 //0x90
33
#define set_CNF1 0x01
34
#define set_CANINTE 0x03
35
36
#define set_BFPCTRL 0x00
37
#define set_TXRTSCTRL 0x00
38
#define set_RXB0CTRL 0x60
39
#define set_RXB1CTRL 0x60
40
#define set_CANCTRL 0x00
41
#define set_CANCTRL_LSO 0x60
42
#define set_CANCTRL_CONFIG 0x80
43
44
int rxstat, msg_id, msg_length, msg_RTR, msg_data[8];
45
46
void setup() {
47
//  pinMode(2, INPUT);
48
  Serial.begin(115200);
49
  delay(5000);
50
  pinMode(CS, OUTPUT);
51
  digitalWrite(CS, HIGH);
52
  SPI.begin();
53
  SPI.setFrequency(4000);
54
  SPI.setCPOL(1);
55
  SPI.setCPHA(1);
56
  //  spirw(mcp_Reset); // reset the MCP2515
57
//  delayMicroseconds(10);
58
59
  while((ReadRegister(mcp_CANSTAT)>>5) != mcp_MODE_CONFIG) {
60
    Serial.print("Not in configuration mode");
61
    WriteRegister(mcp_CANCTRL, set_CANCTRL_CONFIG);
62
63
64
65
  digitalWrite(CS, LOW);
66
  SPI.transfer(mcp_WriteRegister);  // write to register command
67
  SPI.transfer(mcp_CNF3); // start at CNF3
68
  SPI.transfer(set_CNF3); // settings for CNFx:
69
  SPI.transfer(set_CNF2);
70
  SPI.transfer(set_CNF1);
71
  SPI.transfer(set_CANINTE);  // settings for CANINTE
72
73
74
  // Serial.println(ReadRegister(mcp_CNF2), BIN);
75
76
  WriteRegister(mcp_BFPCTRL, set_BFPCTRL);
77
78
  WriteRegister(mcp_TXRTSCTRL, set_TXRTSCTRL);
79
80
  WriteRegister(mcp_RXB0CTRL, set_RXB0CTRL);
81
82
  WriteRegister(mcp_RXB1CTRL, set_RXB1CTRL);
83
84
  WriteRegister(mcp_CANCTRL, set_CANCTRL_LSO);
85
86
  while((ReadRegister(mcp_CANSTAT)>>5) != mcp_MODE_LISTENONLY) {
87
    Serial.print("Not in listen only mode");
88
89
90
91
  Serial.print("CAN init ok");
92
93
94
void loop() {
95
  rxstat = ReadWrite(mcp_RXSTATUS);
96
97
  if(bitRead(rxstat, 6)) { // Message in RXB0
98
99
    SPI.transfer(mcp_READRXB0SIDH);
100
    msg_id = SPI.transfer(0x00) << 3;
101
    msg_id |= SPI.transfer(0x00) >> 5;
102
    SPI.transfer(0x00);
103
    SPI.transfer(0x00);
104
    msg_length = SPI.transfer(0x00) & 0x0F;
105
    msg_RTR = bitRead(rxstat, 3);
106
    for(int i = 0; i < msg_length; i++) {
107
      msg_data[i] = SPI.transfer(0x00);
108
109
110
    PrintData();
111
112
  if(bitRead(rxstat, 7)) { // Message in RXB1
113
114
    SPI.transfer(mcp_READRXB1SIDH);
115
116
117
    SPI.transfer(0x00);
118
    SPI.transfer(0x00);
119
120
121
122
123
124
125
    PrintData();
126
127
128
129
130
int Read() {
131
132
  int _datain = SPI.transfer(0x00);
133
134
  return _datain;
135
136
137
int ReadWrite(int _dataout) {
138
139
  SPI.transfer(_dataout);
140
141
142
  return _datain;
143
144
145
void WriteRegister(int _address, int _dataout) {
146
147
148
  SPI.transfer(_address);
149
150
151
152
153
int ReadRegister(int _address) {
154
155
  SPI.transfer(mcp_ReadRegister);
156
157
158
159
  return _datain;
160
161
162
void PrintData() {
163
  Serial.print("ID: ");
164
  Serial.print(msg_id);
165
  Serial.print(" ");
166
  Serial.print("Data: ");
167
168
    Serial.print(msg_data[i]);
169
    Serial.print(" ");
170
171
  Serial.print("\r\n");
172
