Seems simple, but i am done with this question... May be smart guys here already have an answer... I have an N bit Register with any one of the possible 2^N values. Need to retrieve the position of Most Significant '1' in the register. eg:- Consider a 4 bit register reg <= '0101' . Output should be 2. OR once again reg <= '1101' . Output should be 3. Need a hardware algorithm for this... Cracks my head....
Edited by User
There is no such thing like an 'hardware algorithm'. I think you meant an: 'algorithm, realized in hardware'. What about porting a software solution into an hardware? There are plenty of results for the search term "most significant bit set". Probably some in pure hardware too. A very famous hit, I assume one of the most often cited results, is: http://graphics.stanford.edu/~seander/bithacks.html
There is no such thing like an 'hardware algorithm'. I think you meant an: algorithm, realized in hardware'. yep Klaus... thank you for the correction of context. 'algorithm, realized in hardware' seems the correct way of expressing it.
Was a pleasure. :-) If you need help for transforming an algorithm expressed in an imperative language to a hardware description, feel free to ask here any further question, provided it is 'specific'. It may help you, if you reconsider you basic knowledge about the hardware structure of a common cpu. This would lead to a merely over-engineered design, but is a good start for optimization. But another solution came to my mind: What about the most simple solution? A look-up-table? Not realy educiational but easy. You question may be read like asking for a generic solution. So a look-up-table may be inefficient for greater bit counts, though.
And I need help with English. :-) Should be: "If you need help with transforming ..."
How much time do you have? N cycles? Make a shift register and a counter.
No constraint on numb of cycles... method is the only concern. I tried with an up/down counter with shifter... But was no success... Can u elaborate on that ' VHDL hotline '
antony mathew wrote: > No constraint on numb of cycles... method is the only concern. I tried > with an up/down counter with shifter... But was no success... Can u > elaborate on that ' VHDL hotline ' "No constain on number of cycles"...where is the problem then? Just copy the register to a temporary one and shift left until the leftmost bit is 1. Count the amount of necessary shifts.
Try that: http://www.lothar-miller.de/s9y/archives/55-Finde-das-MSB.html You will see several solutions for that problem...
