Forum: µC & Digital Electronics Getting PWM counter value STM8S003K3
von Lior M. (malikl)
hello,
MCU: STM8S003K3
In my application I using 16MHz of system clock and l create a PWM (in
this case PWM_D) of 200Hz generated by 4MHz clock. Therefor my timer's
counter value is (4M/200=) 20,000.
Also, l have another PWM (in this case PWM_Input) which consider as
input interrupt.
l would like to get the PWM_D counter each time l get an interrupt
caused by PWM_Input.
At the interrupt handler l wrote:
#pragma vector = 6
__interrupt void EXTI_PORTB_IRQHandler(void)
prevTmpTim2Counter = tmpTim2Counter;
tmpTim2Counter = TIM2_GetCounter() ;
if (GPIO_ReadInputPin(GPIOB, GPIO_PIN_5) == 0)
delta = tmpTim2Counter - prevTmpTim2Counter;
this code gives us the delta Toff of the PWM_Input.
So, if PWM_Input is 200Hz and 50% duty cycle, l suppose to get counter
value of 10,000. (Because the counter value of 200Hz is 20,000 as we
calculate before).
However, I got delta of 9900 +/- 250 i.e. sometimes l get values above
10,000 but mostly under 10,000.
In addition, if we take in consider the identification of the MCU to
alternate between "1" to "0" in different voltage (depend on the
hysteresis voltage), yet we should get the same delta, Not perfect 10000
but same delta each time.
please your advice soon as possible.
Thanks, Lior
von Pd G. (pdg)
Maybe you are using the internal RC clock, which is a free running
oscillator? It can be trimmed to a certain accuracy, but it still
provides an accuracy of +-1%, while uncalibrated it is +-5% (see
datasheet, pg 63).
