Forum: FPGA, VHDL & Verilog M9K memory block issue in Cyclone IV
Author: jeorges FrenchRivera (Company: xlue) (khal1985)
I'm trying to use the M9K memory block of my FPGA cyclone IV.
For that purpose I use the Mega-wizard of Quartus II 10.1sp1 Web
Edition.
I implemented the 1 port RAM with single clock, the entity generated
looks like the code below:
  entity RAM_1Port IS
PORT
    address  : IN STD_LOGIC_VECTOR (4 DOWNTO 0);
    clock    : IN STD_LOGIC  := '1';
    data    : IN STD_LOGIC_VECTOR (15 DOWNTO 0);
    wren    : IN STD_LOGIC ;
    q      : OUT STD_LOGIC_VECTOR (15 DOWNTO 0)
END RAM_1Port ;
To test this memory, i have created the code below:
-- Instantiate the RAM single port mode
RAM1: RAM_1Port port map(RAM_address,CLOCK_50,RAM_data_IN,RAM_wren,Output_RAM);
test: process(CLOCK_50,KEY) -- asynchonos process
   begin
     IF (KEY='0') THEN        -- when reset is selected
       -- init signals RAM Single port
       wr_address <=(others => '0');
       RAM_address<=(others =>'0');
       RAM_data_IN<=(others =>'0');
       RAM_wren<='0';
       Write_Ok<='0';
     ELSIF(rising_edge(CLOCK_50)) then
        if(Write_Ok='0') then  -- start writing
        RAM_wren<='1';
        RAM_address<=std_logic_vector(to_unsigned(10, 5));
        RAM_data_IN<=std_logic_vector(to_unsigned(1984, 16));
        cpt<=cpt+1;
        if(cpt=1) then
          Write_Ok<='1';
          cpt<=0;
        end if;
       end if;
       if(Write_Ok='1') then  --start reading
        RAM_wren<='0';
        cpt<=cpt+1;
        RAM_out<=Output_RAM;
        if(cpt=1) then
          Write_Ok<='0';
          cpt<=0;
        end if;
      end if;
   end if;
 end process;
END;
The problem i have is that the output RAM_out is always zero, i don't
understand why.
Can you help on this please if you have an idea?
Best regards
Author: P. K. (pek)
I'd observe the signals "cpt" and "Write_ok" in the Simulator (anyway,
observe them all, so you'll learn what's going on, and what is possibly
not solved very good in your test module).
From the code, it's not clear, what "cpt" is, and how it has been
initialzed. If it's not 0 or 1 at start, you'll end up with Trouble
(e.g. if ist value is -37 or 2). Anyway, ist not quite clear to me what
this "cpt" is good for...
: Edited by User
Thanks you pek for your answer. cpt is integer range 0 to 15 and
initialized zero, i used it because in the beginning i have a loop of 16
iterations.
Now, i remove the cpt from my code and I always have the same problem.
You find enclosed a screenshot of my signals.
Best regards
Author: P. K. (pek)
If SignalTap shows signals in red they are (in case of a bus sometimes
partially, so open it to see more) not available (after synthesis).
So check why those (red marked) signals where synthesized away. Make an
interpretation of the warnings Quartus issues.
I did not pay attention to red signals thinks.
I have this warning concerning the output but i don't understand:
Warning (14320): Synthesized away node
"RAM_1Port:RAM1|altsyncram:altsyncram_component|altsyncram_hci1:auto_gen
erated|q_a[0]".
How can I resolve this warning ?
Best regards
Author: P. K. (pek)
That means as much as "your RAM output is never assigned". In other
words, your code is erroneous. Time to set up a simulation (the thing
you do BEFORE synthesis) with all signals displayed...
It's very strange when i assign RAM output to LED(mapped to the leds in
the board) the warning disappear but when it assigned to a an internal
signal there is a warning.
Any case i can't exploit the output of this RAM.
I don't know what going with the magafuntions of altera, never work for
me.
Best regards
Author: P. K. (pek)
> me.
I think it's useless to blame the mega function. Start to simulate your
design and display _ALL_ your signals to learn what happens.
You are right pek,it's unless to blame the mega function.
I simulated as you suggested and it works. But with quartus and using
the signal tap, i still have Zero in the output of the RAM.
Best regards
Author: P. K. (pek)
You should look out for the warning
> Warning (14284): Synthesized away the following node(s):
And investigate what it says. Even when observing with SignalTap, the
synthesizer throws unused logic (not having influence on any outputs)
away. To maintain the function, attach the outputs to any unused output
pin of the FPGA and observe again.
I don't have the
> Warning (14284): Synthesized away the following node(s): because i connected as
you suggested the output to the LED in my board, in the same time i can see that
it works. But, when this output is connected to a global signal, its value is
always zero.  It's normal ?
Best regards
Author: P. K. (pek)
If the global signal leads to nowhere, the answer is yes. Even a
"global" signal that does not drive any output has no function and
therefore may be taken out of the design by optimisation.
The fact that a SignalTap logging is not considered as an "output" and
the logic is optimized away anyway is a little nuisance but you can deal
with: As soon as signals either are registered or going through the
interface of a (sub)-entity you will be able to observe them with
SignalTap (however, they will be optimized away anyway as soon as you
switch of SignalTap, as they still have no influence on any output).
thank you very much Pek for your help. Have a good day.
Best regards
  • [vhdl]VHDL code[/vhdl]
