Forum: FPGA, VHDL & Verilog How to generate random delay in "generate" loop?
von RandomDelay (Guest)
How can I generate random time delay in following code? What I found so
far is only random generation in a process with function "uniform". I
want to generate random time delays during compile time. Is it possible?
Thanks.
  for i in 0 to nr_entries-1 generate
    multiple_n: w_entity
      generic map (delay => (i+1) * 1 ps , chain_len => nr_chains) -- Delay must be "random" from 100 to 300 ps
      port map (
        rst_i => s_rst,
        out_o => s_inp(i)
  end generate;
I am now generating it from for-variable "i" which is not random.
von Andreas (Guest)
Did you have an Idea, how the syntesizer should release such random
delay time?
Best Regards
von bogomil (Guest)
i suggest this is for Simulation only anyway
