Forum: Analog Circuits Trouble with MAX712
von Nico V. (nicovanduijn)
Hey guys,
I've been fooling around with a charging circuitry for a while now, and
I can't get it to run for the life of me. Here's what I'm doing:
I am trying to charge a 12-cell NimH 5000mAh battery pack.
1) I'm charging with C/4, to 5000mAh, thus
- Ifast around 1.2 A
- Using voltage slope detection
It follows:
PGM2: BATT-
PGM3: BATT-
2) Since I use 12 cells:
PGM 1: BATT-
PGM 0: REF
3) For DCin I use a 24V wallwart. Should suffice (12x1.45 + 1.5=18.9)
4) Rsense of 0.22R seems reasonable
5) The datasheet states that for >11 cells you need a cascode connection
for BATT+ to avoid exceeding its max specs.
6) And since my supply is larger than 20V, I need a cascode for DRV as
well
7) I'm trying to use status LEDs for POWER and FASTCHARGE, each using
around 10mA. This means there should be a total of about 30-45mA flowing
into the V+ node, right?
 (24-5)/R1=40, so I chose 470R for R1.
8) I connected Vlimit (pin 1) to V+, according to the datasheet page 5
that makes the max voltage 1.65V. (Not sure if I should use Vref instead
here, but I thought that would make the max cell voltage 2V, in which
case my supply voltage wouldn't be large enough. Besides, if I charge a
NiMH cell to 2V, god know what happens)
I attached a schematic of my circuit.
The whole thing doesn't work at all. My LEDs remain dark, I measure 1.7V
at V+ (should be 5, right?), Vref is at 0.707V (Should be 2V).
I've been messing around with this so much now, that I am fairly certain
that I somehow burned out all four of my MAX712s that I had. Is there a
simple test circuit to determine its proper functionality?
Is there something fundamentally wrong with my circuit? I'm uncertain on
a few issues:
- Whether I did the two cascode connections properly
- Whether I am powering the MAX712 right (Taking into account the two
LEDs, base current for T1 and the 5-20mA for the MAX)
- Whether I'm doing the LED thing correctly
- Point 8 from above
- Whether my DCin is high enough
- Whether my MAX712 are defect
I'm pretty lost, any help would be greatly appreciated!
best,
Nico
: Moved by Admin
