Forum: FPGA, VHDL & Verilog verify the fcs of ethernet frame
Author: Sidharth Kashyap (Company: cdac) (kashyap0)
hi
 i am trying to transmit a Ethernet frame from fpga to pc.
 my udp frame is:
constant udp_frameB :frame60:=
         (x"FF",x"FF",x"FF",x"FF", -- mac dest
    x"FF",x"FF",x"00",x"00",
    x"00",x"04",x"14",x"13", -- mac src
    x"08",x"00",x"45",x"00", -- IP header
    x"00",x"2E",x"00",x"00",
    x"00",x"00",x"40",x"11",
    x"7A",x"C0",x"00",x"00", -- IP src
    x"00",x"00",x"FF",x"FF", -- IP dest
    x"FF",x"FF",x"00",x"00", -- port src
    x"50",x"DA",x"00",x"12",-- port dest + len
    x"00",x"00",x"42",x"42", -- checksum udp + data "B"
    x"42",x"42",x"42",x"42",
    x"42",x"42",x"42",x"42");
for the above frame i have calculated the FCS using the crc-32
polynomial-X"04C11DB7".
FCS is-X"D96F0BBF"
I have adopted following method to calculate FCS:
IEEE 802.3 defines the polynomial M(x) as the destination address,
source address,length/type, and data of a frame, with the first 32-bits
complemented. The result of CRC is complemented, and the result is the
IEEE 802.3 32-bit CRC,referred to as the Frame Check Sequence (FCS)
field. The FCS is appended to the end of the Ethernet frame, and is
transmitted highest order bit first (x31, x30,…, x1, x0).
please tell me ,Is FCS correct or not?
and also tell me that if the FCS is not correct then will wireshark
capture it or not?
Author: Daniel Abrecht (daniel-a)
I don't know.
> capture it or not?
In most cases, it won't. If a switch or router is betwen the fpega and
the pc, it should discard the ethernet frame if the fcs is wrong. Most
ethernet/wlan cards are verifying the checksum and the os will never see
the checksum. If you haven't one of these cards, and there is nothing
between the pc and the fpega, wireshark should be able to capture
ethernetframes with wrong fcs. Otherwise, it won't.
Author: Schlumpf (Guest)
Sidharth, why the heck do you start a new thread for every question on
the same subject?
  • [vhdl]VHDL code[/vhdl]
