Forum: FPGA, VHDL & Verilog help: make the clock divider twice as fast or 2 Hz.
Author: johnsa (Guest)
Hello
This is one part of school assignment that trying to figure it out. I
have done the rest parts but I'm stuck at this one:
"This given module take the 50 MHz clock_50 of the DE2 board and divides
down to generate a CLKout of 1 Hz. Modify this given module to make the
clock twice as fast or 2 Hz"
and here is the code:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity DIVIDER is
port ( CLKin: in std_logic;
reset: in std_logic;
CLKout: out std_logic);
end DIVIDER;
architecture behavioral of DIVIDER is
signal count: integer:=0;
signal temp : std_logic := '1';
begin
process(CLKin,count,reset)
begin
if(reset='1') then count<=0; temp<='1';
elsif(CLKin'event and CLKin='1') then count <=count+1;
if (count = 25000000) then temp <= NOT temp; count<=0;
end if;
end if;
CLKout<= temp;
end process;
end behavioral;
Author: manne (Guest)
this is a very funny school because they are using old synopsis libs
which are outdated and they use "temp" as a signal name where there is
nothing temporary about.
Then it uses asnch clocking and a user signal inside the clocked part in
the sensitvity list
This code is wimmeling for errors...
ok but do you know how to answer the question?
Author: lambda (Guest)
This shouldn't be that hard for you. Try to figure out how the 50 MHz
(Hint: 50000000 Hz) is divided to get 1 Hz. Then alter this to get twice
as much clock changes as before.
1 Hz means one full period per second which means two changes in
polarity per second.
so i should change 25000000 to 50000000?
ohh i got it i should change it to 12500000. is that right?
All of those numbers are wrong!!
A counter from 0 to 10 counts 11 steps. So a counter from 0 to 25000000
counts 25000001 steps. That's simply and basically wrong.
So to get 2 Hz a counter must count from 0 to 12499999 and then the
output must be toggled.
Author: Verilogi (Guest)
a toogle is not a good indicator for a clock, better us only one small
tick at 2499999
  • [vhdl]VHDL code[/vhdl]
