Forum: FPGA, VHDL & Verilog Verilog error - can`t find solution
Author: Alexandru Chiser (xeyow)
I have this code:
`timescale 1ns / 1ps
module blacks(input [31:0] b,
    input left,
    output [3:0] nr_black);
integer i = 0;
integer nr;
assign nr_black = 4'b0000;
always @ (*) begin
  if(left==0)
  begin
    while (i < 31)
    begin
      if (b[i] == 0)
        i=i+1;
      else
      begin
        nr=0;
        while (b[i] == 1)
        begin
          i=i+1;
          nr=nr+1;
        end
        if (nr >= 2)
          nr_black = nr_black + 4'b0001;
      end
    end
  end
  else;
end
endmodule
It gives me this error: "Procedural assignment to a non-register
nr_black is not permitted, left-hand side should be
reg/integer/time/genvar" on line 46
line 46 is this one: nr_black = nr_black + 4'b0001. How can i fix this
program?
My nr_black is the output on 4 bits, and whenever nr is higher or equal
than 2, i want to increment nr_black with 1. How do i do that? TY
: Edited by User
Alexandru Chiser wrote:
> How can i fix this program?
You must add a clock to your design. At the moment you have a
combinatorial loop (in theory a counter running at maximum speed, in
reality a noise generator). And such a thing is nearly useless...
I can not add a clock in this. I must somehow count the output
(nr_black) whenever i find out that nr is higher or equal than 2. I
can`t add a clock. I need to do this without a CLK
Author: bko (Guest)
Your Code:
The Errormessage:
Just do what the error mesage says:
output reg [3:0] nr_black);
Done! Now this error showed up:
"Target <nr_black> of concurrent assignment or output port connection
should be a net type." on line 28
Line 28: assign nr_black = 4'b0000;
Author: fpgakuechle (Guest)
Initial assignment by reset will do the trick:
http://stackoverflow.com/questions/10005411/assign...
Best regards
I tried to make nr_black wire, and then initialize a wire [3:0] counter.
And when nr>=2 counter = counter + 1. And at the end: assign nr_black =
counter.
but it gives me this error: Procedural assignment to a non-register
counter is not permitted, left-hand side should be
I can`t figure it out...
It's a difference what (reg/wire) can be assigned within an
always @ (*) begin block and what beside such a block:
   blocking assignment vrs. non-blocking assignment
Maybe this helps:
http://www.asic-world.com/tidbits/wire_reg.html
Author: Long Tran Van (Company: Ha Noi- Vietnam) (longtv)
Hi  Alexandru Chiser !
you only edit "output [3:0] nr_black" into "output reg  [3:0] nr_black"
your code when compiled it make circuit combination, but you used "
alway" so output you is used, it used in "always" must be " reg" not
"wire". My english is not good, that i written make you difficult
understand, if you want to call me, skype: tv_long.
: Edited by User
Yet, i can`t make it work. I made it reg / wire, added another wire to
count and then assign the output = counter. Nothing works...
: Edited by User
  • [vhdl]VHDL code[/vhdl]
