Forum: FPGA, VHDL & Verilog Connecting PC to FPGA and LED matrix
Author: Moi Fener (jmaxout)
Hi! This is the first time I have ever worked with FPGA and VHDL. I am
trying to connect a PC with a FPGA to control two led matrices using
buffered memory. So I was wondering if RAM or FIFO would be best for
this? Sorry for my English not my native language..
Author: Peter (Guest)
1 useful
To connect your FPGA to a PC you need a Interface (RS-232  USB
Firewire / Ethernet). Which one you choose depends mainly on your
knowledge and your requirements in terms of data throughput.
RAM is a special type of memory. No FPGA has one, it must be connected
externally. Maybe you have a development board which has RAM on board.
FIFO is not a memory. FIFO is a memory model which says, that data that
comes in first, will be processed first. This ist not a memory. A FIFO
manages your data (e.g. in RAM) in a certain way.
1 useful
Moi Fener wrote:
> I am trying to connect a PC with a FPGA to control two led matrices
> using buffered memory. So I was wondering if RAM or FIFO would be best
> for this?
Go one step back. And then start with the most simple application on a
FPGA: a blinking LED, the "hello world!" of hardware. After that
implement a chasing light, then a RS232 interface, then try to control
your matrix LEDs, then generate a running pattern on the matrix, then
display the pattern into RAM and display it
And so step after step you will reach your desired destination. But not
by tricking around with FIFO and RAM at this point of the design.
> externally.
Every FPGA has RAM inside. More: usually its DualPorted RAM inside...
Moi Fener wrote:
> So I was wondering if RAM or FIFO would be best for this?
Just a little hint: I would not need a FIFO for this application. The
DualPort RAM inside the FPGA is perfect good for the job.
How big?
And what means "to control" them? Showing a video?
Thank you for your reply! I am basically trying to send data from the
Computer using a serial port. The matrices are 2 8x8. Trying to write
something on the matrices.
  • [vhdl]VHDL code[/vhdl]
