Forum: ARM programming with GCC/GNU tools Reload an ELF File
von Andreas K. (halma)
Hy!
I would like to know if somebody has any experience with elf files.
My problem is: I have a program which i compile with a gcc Compiler and
this program runs on a Cortex A9 Prozessor.
In the program there is a pointer to a dummy function. During the
program the user should be able to load a function to a specific space
in RAM with all neccessary initialize things.
After loading this program the pointer should be set to the new function
and this function should run.
The reload of the function should take place without stopping the main
program.
I found something like Dynamik kinking with ELF files, but I Need some
help with this Topic please.
Ülease ask if you Need more Information to this Topic
Best regards
Andi
von Dr. Summer (Guest)
Use the exec() family of functions to replace the current process image
with a new one from another executable file.
You can instead load library files using dlopen() and call functions
from them using dlsym(). If your kernel/loader supports ELF, these files
can be im ELF format.
von Karl Käfer (Guest)
Hi Andreas,
> program.
If you have an operating system with a dynamic linker (like, for
example, Linux), then you could try the dl{open,error,sym,close}(3)
functions from dlfcn.h. These provide dynamic loading as well as
resolving the symbols of shared object files.
HTH,
Karl
thx for your answers, but I do not have the dlfcn.h file on my pc.
I can not find it in my gcc Settings.
Do you know what to do?
Thx
von Markus F. (mfro)
what I have (successfully) done in the past (on another platform) was
having the bootloader read S-record files from SD-card into memory,
transform to binary and execute them.
This basically just needs two suitable linker scripts (they must agree
on the entry point which is just a function without parameters returning
an int), the SD-card read routines and an S-record parser.
I think that should work as well for ELF files.
Hi Andreas,
dlfcn.h is Linux-specific, thus if you work on a Windows PC you won't
have it. Maybe you'd try and compile on the target?
HTH,
Karl
I have another question:
What is about writting my own elf loader? Is this a very complicated
thing or is it more like straight forward?
I do not know but I am looking in the internet for this thing but I do
not really found some helpfull things. Only the CONTIKI System seems do
be something I need.
Would be cool if you could help me again.
Maybe you could finally tell us what Operating System you are using on
your Cortex-A9. Linux supports dlopen(), others might have their own
functions for loading ELF's.
von halma (Guest)
Hey,
thank you for your interesst in my problem.
I do not use an operating system. We have written our own bootloader to
start the processor and init the ram and flash.
Then we load our basic program down with the dummy function. And during
the runtime I want to download another function to replace the dummy
function without stopping the old program.
So I do not have and I also do not want to use Linux.
I think I will have to write my own elf loader to solve my problem, or
do you have another idea?
von Rolf Magnus (Guest)
Yes, if you don't have an operating system, you can obviously not use
any operating system services and have to do everything on your own.
So you have to implement your own dynamic linking system. Maybe you can
get some ideas on how to do that from the linux kernel and its support
for loadable kernel modules.
I wouldn't call that "dynamic linking system". As far as I understand,
what's needed is more like old style "overlays" and that should be
pretty easy to implement.
If you know the load address upfront (at least that's what I
understood), you can link your executable to a fixed address and do not
need to relocate anything. The "overlay" loading process then just boils
down to reading an ELF file (probably easiest with using one of the
freely available libelf's that are around), finding the relevant
section(s), extract them from the file and copy to destination. If you
set up your linker scripts accordingly, you can even use common areas in
the data and bss section to exchange data ("poor man's shared memory").
Do not forget to flush cache(s) if you have any since you copied code.
Then just cross fingers and call it.
: Edited by User
Thank you very much for your answer, but I am a real noob in using elf
files. Could you post me a link which elf file reader you would use, or
do you have an idea which one is the best?
To explain my Problem again a litte bit more in Detail:
I have two projects in Eclipse and I am able to compile the two
projects. I also have the adress where the new function should start in
memory, for example at: 0x17600000
If I download the file with Eclipse to this location everything works
fine, but now I want to automatic this process.
Thanks for help again.
