Forum: FPGA, VHDL & Verilog Interfacing EFB (UFM) with Mico8 Wishbone
Author: Reto B. (schnuber)
Hi
I have a MachXO2 Device LCMXO2-7000HE. In my design I have the Lattice
Mico8 softcore with Wishbone interface (downloaded Reference design).
Then I have an EFB block where I want to use the UFM.
There are other peripherials to the controller such as UART and they all
work fine.
But I don't manage to get the communication going with the UFM. Maybe I
am doing something wrong with the protocol or timing. Can anyone provide
me a reference code where I can see how the communication with the UFM
via Wishbone is done.
Any help appreciated.
Sincerely
Author: Lattice User (Guest)
How to access the UFM you will find in this docoument page 73 ff
http://www.latticesemi.com/view_document?document_id=46300
Thanks
I actually studied that document already, but I am still not able to
establish communication. That is why I ask if someone can provide me a
working reference code either in C or assembler.
But maybe you are right, I have to analyze the wishbone signals with an
logic analyzer to see whether I meet the timings exactly as described in
this document.
Sincerely
Sorry i can't provide a sample for the Mico8, only general help.
(i have used a simple FSM to read one page in my projects)
Don't worry about the WB timing, the Mico8 core should do it correctly.
enable the configuration interface
0x80   -> 0x70  Open frame
0x74   -> 0x71  Cmd
0x08   -> 0x71
0x00   -> 0x71
0x00   -> 0x71
0x00   -> 0x70  Close frame
WAIT 5 usec.
Set page address
0x80   -> 0x70
0xB4   -> 0x71
0x00   -> 0x71
0x00   -> 0x71
0x00   -> 0x71
0x40   -> 0x71
0x00   -> 0x71
PageH  -> 0x71
PageL  -> 0x71
0x00   -> 0x70
read page
0x80   -> 0x70
0xCA   -> 0x71
// here i have a small delay, not sure why
0x10   -> 0x71
0x00   -> 0x71
0x01   -> 0x71
          0x73 -> Byte 0
          0x73 -> Byte 1
          0x73 -> Byte 15
0x00   -> 0x70
disable config interface
0x80   -> 0x70
0x26   -> 0x71
0x00   -> 0x71
0x00   -> 0x71
0x80   -> 0x70
bypass
0x80   -> 0x70
0xFF   -> 0x71
0xFF   -> 0x71
0xFF   -> 0x71
0xFF   -> 0x71
0x80   -> 0x70
Thanks Lattice User
My Assembler Code in Mico8 looks like this.
Here I try to read the device ID as you suggested in the first post.
When I read back the Device ID into register r17-20 I just got all zeros
in it. I guess I have to analyse with a Logic Analyzer to see what is
wrong.
What is your opinion on this code
  movi r15, FLASH       ;Address of peripherial
  movi r11, CFGCR       ;Port address Control Register 0x70
  movi r13, CFGTXDR   ;Port address Transmit Register 0x71
  movi r9, CFGRXDR   ;Port address Receive Register 0x73
  movi r16, READ_DEVICE_ID ;Define Command 0xE0
  movi r12, ZERO_OP   ;Null Operand 0x00
  movi r10, START_CMD ;Start Byte 0x80
  movi r8, END_CMD ;Start Byte 0x00
;Starte Kommando
  exporti r10,r11   ;Assert CFGCR[WBCE]
;Send Command
  exporti r16,r13 ;Send Command READ_DEVICE_ID
  exporti r12,r13   ;Send 0x00 operand 3x
  exporti r12,r13
  exporti r12,r13
;Read Device ID
  importi r17,r9
  importi r18,r9
  importi r19,r9
  importi r20,r9
;End Kommando
  exporti r8,r11   ;De-assert CFGCR[WBCE]
Hmmmm
What memory modell are you using?
For medium modell my version of the LM8 reference modell documents R13
as page pointer. From your code it looks like you are using R15.
Yes I have r15 and r14 as address register.
I actually dont know what memory model I use, but it is the Reference
Design RD1026 configured to 32 General Purpose registers.
: Edited by User
Which version of the Mico8 are you using?
The latest 3.15 supports three meory modes:
small:  no page pointer
medium: R13 is page pointer
large: R13,R14,R15 is page pointer
I analyzed the Wishbone signals and surprise: the UFM block actually
respond to the Read Device ID request. However, due to some timing
issues the Mico8 importi implementation somehow is not able to capture
the response from the UFM.
My version of Mico8 is 3.1. I think I might have to update it to 3.15 as
I infer by your comments. This might help.
Ok see you later, maybe I can do it by Friday.
Sincerely
  • [vhdl]VHDL code[/vhdl]
