Forum: FPGA, VHDL & Verilog Hello world on Atlys Spartan-6 xc6slx45
von Slim H. (slimhmidi)
I want to do a hello world program with my atlys spartan-6 xc6slx45.I
opened EDK I create a new Projet using BSB then I create a new
microblaze using PLB interconnect.After that I generate the
Bitstream,after that I export design (SDK).When the window of the SDK
opened I crate a new hello world project using C code.then I clicked
program FPGA but I got this error :
Program FPGA failed.
Connection to board failed.
Failed to open Jtag cable.
Cable target is not connected to the host.
The board was powered on and I use only one usb cable which is connected
from my PC to the program port.What can I do ??,
von fpgakuechle (Guest)
> xc6slx45.I
There are two mini-usb ports on the altys one mark PROG one marked UART.
Maybe you connected the wrong one. Digilent has an PC-application
("Adept") to connect with the board. Try this,
Best Regards,
I solved this problem but I get an other error which is Microblaze is
under Reset.
von Aurel (Guest)
How did you solve your problem?
I have the same one...
Thanks a lot
