Forum: FPGA, VHDL & Verilog For loop in VHDL
von Chris R. (regform)
Good day,
I am trying to use a for loop in VHDL to create an SLL "calculator" (for
lack of a better term) as part of a MIPS assembly system.
I get the following errors:
# ** Error: C:/Users/Christian/Documents/ift 1227/dev 5
Mips/one_cycle_mips.vhd(179): near ":=": expecting ':'
Mips/one_cycle_mips.vhd(184): No feasible entries for infix operator
"sll".
Mips/one_cycle_mips.vhd(184): Type error resolving infix expression
"sll" as type ieee.std_logic_1164.STD_LOGIC_VECTOR.
Here is the part of the code that does not work. I have compiled my code
one step at a time, so I know that everything else works.
 shift_tmp <=  RTdata;
process (shift, RTdata)
 variable i := integer range 0 to 31;
 i:=0;
begin
  for i in 0 to (to_integer(unsigned(shift))) loop
    shift_tmp <= shift_tmp sll 1;
  end loop;
 end process;
shift_out <=  shift_tmp;
Here is the entire code:
-- mips.vhd
-- From Section 7.6 of Digital Design & Computer Architecture
-- Updated to VHDL 2008 26 July 2011 David_Harris@hmc.edu
-- Modified at U de Montreal 2015
library IEEE;
use IEEE.STD_LOGIC_1164.all; use IEEE.NUMERIC_STD.all;
entity One_Cycle_MIPS is
  signal RTdata, dataadr:    STD_LOGIC_VECTOR(31 downto 0);
  signal clk, reset,  memwrite: STD_LOGIC := '0';
  signal pc, instr,
         readdata: STD_LOGIC_VECTOR(31 downto 0);
------------Data Memory----------------------------
  type ramtype is array (63 downto 0) of STD_LOGIC_VECTOR(31 downto 0);
  signal mem: ramtype;
----============Pgm to execute==================================
  type MemInstType is array (0 to 63) of STD_LOGIC_VECTOR(31 downto 0);
  constant MemInst: MemInstType := (
    X"20020005",   -- main:   addi $2, $0, 5
    X"2003000c",   --         addi $3, $0, 12
    X"2067fff7",   --         addi $7, $3, −9
    X"00e22025",   --         or $4, $7, $2
    X"00642824",   --         and $5, $3, $4
    X"00a42820",   --         add $5, $5, $4
    X"10a7000a",   --         beq $5, $7, end
    X"0064202a",   --         slt $4, $3, $4
    X"10800001",   --         beq $4, $0, around
30
    X"20050000",   --         addi $5, $0, 0
31
    X"00e2202a",   -- around: slt $4, $7, $2
32
    X"00853820",   --         add $7, $4, $5
33
    X"00e23822",   --         sub $7, $7, $2
34
    X"ac670044",   --         sw $7, 68($3)
35
    X"8c020050",   --         lw $2, 80($0)
36
    X"08000011",   --         j end
37
    X"20020001",   --         addi $2, $0, 1
38
    X"ac020054",   -- end:    sw $2, 84($0)
39
    others => X"00000000");
40
41
-- Signaux MIPS----------------------------------------------
42
  signal memtoreg, alusrc, regdst, regwrite, pcsrc: STD_LOGIC;
43
  signal jump, adr3contr: STD_LOGIC_VECTOR(1 downto 0);
44
  signal zero: STD_LOGIC;
45
  signal alucontrol: STD_LOGIC_VECTOR(2 downto 0);
46
47
 -- Format Instructions-------------------------------------------------
48
  alias op    : std_logic_vector (5 downto 0) is instr(31 downto 26);
49
  alias funct : std_logic_vector (5 downto 0) is instr(5 downto 0);
50
  alias rs    : std_logic_vector (4 downto 0) is instr(25 downto 21);
51
  alias rt    : std_logic_vector (4 downto 0) is instr(20 downto 16);
52
  alias rd    : std_logic_vector (4 downto 0) is instr(15 downto 11);
53
  alias imm   : std_logic_vector (15 downto 0) is instr(15 downto 0);
54
  alias shift : std_logic_vector (4 downto 0) is instr(10 downto 6);
55
56
------Signaux Controller-----------------------------------
57
  signal aluop:  STD_LOGIC_VECTOR(1 downto 0);
58
  signal branch: STD_LOGIC;
59
 -----Signaux Maindec---------------------------
60
  signal controls: STD_LOGIC_VECTOR(11 downto 0);
61
62
 --Signaux DATAPATH---------------------------------
63
  signal aluout, lui, wd3, ori, shift_tmp, shift_out: std_logic_vector (31 downto 0);
64
  signal writereg, adr3:   STD_LOGIC_VECTOR(4 downto 0);
65
  signal PCJump, pcnext, pcnextbr, pcplus4, PCBranch, SignImm, SignImmShiftLeft2:
66
67
  signal srca, srcb, result: STD_LOGIC_VECTOR(31 downto 0);
68
69
-- Signaux Register File----------------------------------------
70
  type RFtype is array (31 downto 0) of STD_LOGIC_VECTOR(31 downto 0);
71
  signal RF: RFtype;
72
73
end;
74
--================ARCHITECTURE=========================================
75
architecture test of One_Cycle_MIPS is
76
begin
77
  clk <= NOT clk after 5 ns; -- Generate clock with 10 ns period
78
  reset <= '0', '1' after 1 ns, '0' after 2 ns;
79
80
---Instruction Memory----------------------------------------------
81
  instr <= MemInst(to_INTEGER(unsigned(pc(7 downto 2))));
82
83
------Data Memory R/W----------------------------------------------
84
  process (clk) is
85
  begin
86
   if clk'event and clk = '1' then
87
     if (memwrite = '1') then mem(to_integer(unsigned(dataadr(7 downto 2)))) <= RTdata;
88
     end if;
89
   end if;
90
  end process;
91
92
  readdata <= mem(to_integer(unsigned(dataadr(7 downto 2))));
93
94
---===============mips========================================
95
-- Controller----------------------
96
maindec:  process(op, funct) begin
97
    case op is
98
      when "000000" =>
99
       if funct = "001000" then controls <= "000000100000"; -- JR
100
       elsif funct = "000000" then controls <= "110000000011"; -- SLL
101
       else controls <= "110000001000"; -- RTYPE
102
      end if;
103
      when "100011" => controls <= "101001000000"; -- LW
104
      when "101011" => controls <= "001010000000"; -- SW
105
      when "000100" => controls <= "000100000100"; -- BEQ
106
      when "000010" => controls <= "000000010000"; -- J
107
      when "001000" => controls <= "101000000100"; -- ADDI
108
      when "001111" => controls <= "100000000001"; -- LUI
109
      when "001101" => controls <= "100000001010"; -- ORI
110
      when "000011" => controls <= "100000100000"; -- JAL
111
      when others   => controls <= "------------"; -- illegal op
112
    end case;
113
  end process;
114
  (regwrite, regdst, alusrc, branch, memwrite, memtoreg, jump(1),jump(0),
115
   aluop(1),aluop(0), adr3contr(1), adr3contr(0)) <= controls;
116
117
Aludec: process(aluop, funct) begin
118
    case aluop is
119
      when "00" => alucontrol <= "010"; -- add (for lw/sw/addi)
120
      when "01" => alucontrol <= "110"; -- sub (for beq)
121
      when others => case funct is      -- R-type instructions
122
                    when "100000" => alucontrol <= "010"; -- add
123
                    when "100010" => alucontrol <= "110"; -- sub
124
                    when "100100" => alucontrol <= "000"; -- and
125
                    when "100101" => alucontrol <= "001"; -- or
126
                    when "101010" => alucontrol <= "111"; -- slt
127
                    when others   => alucontrol <= "---"; -- ???
128
                    end case;
129
    end case;
130
  end process;
131
132
  pcsrc <= branch and zero;
133
134
 --===================DATAPATH======================================
135
 -- next PC logic----------------------------
136
  SignImm <= X"ffff" & imm when imm(15) = '1' else X"0000" & imm;
137
  SignImmShiftLeft2 <= SignImm(29 downto 0) & "00";
138
139
  Plus4: pcplus4 <= STD_LOGIC_VECTOR(unsigned(pc) + 4);
140
  BTA: PCBranch <= std_logic_vector(signed(pcplus4) + signed(SignImmShiftLeft2));
141
  JTA: PCJump <= pcplus4(31 downto 28) & instr(25 downto 0) & "00";
142
143
  pcnextbr <= PCBranch when pcsrc = '1' else pcplus4;
144
  pcnext   <= PCJump when jump = "01" else pcnextbr when jump = "00" else srca when jump = "10";
145
146
  updatePC: process(clk, reset) begin
147
    if reset ='1' then  PC <= (others => '0');
148
    elsif rising_edge(clk) then
149
      PC <= pcnext;
150
    end if;
151
  end process;
152
153
-- Register File Logic----------------------------
154
 srca <= (others => '0') when (to_integer(unsigned(rs)) = 0) -- register 0 holds 0
155
                     else RF(to_integer(unsigned(rs)));
156
 RTdata <= (others => '0')  when (to_integer(unsigned(rt)) = 0)
157
                     else RF(to_integer(unsigned(rt)));
158
 srcb <= SignImm when (alusrc = '1') else RTdata;
159
160
 lui <= imm & X"0000";
161
 ori <= X"0000" & imm;
162
163
 wd3 <= result when adr3contr = "00" else lui when adr3contr = "01"
164
  else (ori OR srca) when adr3contr = "10" else shift_out when adr3contr = "11"; -- DATA
165
 adr3 <= "11111" when jump = "10" else writereg; --jal $ra = 31
166
 writereg <= rd when regdst = '1' else rt;
167
 result <= readdata when memtoreg = '1' else aluout;
168
169
 process(clk) begin
170
171
       if regwrite = '1' then RF(to_integer(unsigned(adr3))) <= wd3;
172
       end if;
173
    end if;
174
 end process;
175
176
177
178
179
180
 i:=0;
181
182
begin
183
184
185
  end loop;
186
 end process;
187
188
shift_out <=  shift_tmp;{-- mips.vhd
189
190
191
192
193
library IEEE;
194
195
196
197
198
199
  signal pc, instr,
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
246
247
248
249
250
251
252
253
254
255
256
257
258
  signal RF: RFtype;
259
260
end;
261
262
263
begin
264
265
266
267
268
269
270
271
  process (clk) is
272
  begin
273
274
275
     end if;
276
   end if;
277
  end process;
278
279
280
281
282
283
284
    case op is
285
      when "000000" =>
286
287
288
289
      end if;
290
291
292
293
294
295
296
297
298
299
    end case;
300
  end process;
301
302
303
304
305
    case aluop is
306
307
308
309
310
311
312
313
314
315
                    end case;
316
    end case;
317
  end process;
318
319
320
321
322
323
324
325
326
327
328
329
330
331
332
333
334
335
336
      PC <= pcnext;
337
    end if;
338
  end process;
339
340
341
342
343
344
345
346
347
348
349
350
351
352
353
354
355
356
 process(clk) begin
357
358
359
       end if;
360
    end if;
361
 end process;
362
363
364
365
366
367
 i:=0;
368
369
begin
370
371
372
  end loop;
373
 end process;
374
375
376
377
 -- ALU logic -------------------------------------------------------
378
  process(alucontrol, srca, srcb)
379
   variable sum: STD_LOGIC_VECTOR(31 downto 0);
380
  begin
381
    if alucontrol(2) = '0'
382
         then sum  := STD_LOGIC_VECTOR(signed(srca) + signed(srcb));
383
         else sum  := STD_LOGIC_VECTOR(signed(srca) - signed(srcb));
384
    end if;
385
    case alucontrol(2 downto 0) is
386
      when "000"   => aluout <= srca and srcb;
387
      when "001"   => aluout <= srca or srcb;
388
      when "010"|"110"   => aluout <= sum;
389
      when "111"   => aluout <= (0 => sum(31), others => '0');
390
      when others => aluout <= (others => 'X');
391
    end case;
392
 end process;
393
394
  zero <= '1' when (aluout = X"00000000") else '0';
395
  dataadr <= aluout;
396
397
--========================VERIFICATION=====================================
398
  -- check that 7 gets written to address 84 at end of program
399
process (clk) begin
400
  if (clk'event and clk = '0' and memwrite = '1') then
401
     if (to_integer(unsigned(dataadr)) = 84 and
402
         to_integer(unsigned(RTdata)) = 7) then
403
      report "NO ERRORS: Simulation succeeded" severity failure;
404
     elsif (to_integer(unsigned(dataadr)) /= 80) then
405
       report "Simulation failed" severity failure;
406
     end if;
407
   end if;
408
end process;
409
end;
410
411
412
413
414
415
  begin
416
417
418
419
    end if;
420
421
422
423
424
425
426
    end case;
427
 end process;
428
429
430
  dataadr <= aluout;
Any help is appreciated!!
Thanks,
Chris
von Bitflüsterer (Guest)
Nearly unbelievable. You wrote that code and you are not able to find a
simple syntax error? :-)
I got no hint, which your local time is, but I would say, it's
definately late there. Go to bed, sleep well and have another look
tomorrow.
By the way: Please post long code as attachment, not inline.
Update:
I have changed to the following code:
 variable i : integer range 0 to 31;
begin
    shift_tmp <= shift_tmp(30 downto 0) & "0";
  end loop;
 end process;
This reduces the error to
Mips/one_cycle_mips.vhd(187): near "EOF": syntax error
P.S. - No I have not noticed the syntax error, I have been programming
in VHDL for about six weeks, so what might be simple for you might not
be for me...
:0)
I thought it was due to a lack of sound sleep.
However, an architecture, as it has a 'begin' must have an end as well.
:-) I dont see any other reason which may cause syntax errors at the end
of your file; as I take the code from your first post as still valid.
Btw: Syntax errors are not a matter of knowledge but of memory, so far
as I am concerned. It's like with good chess players. Most of the time
they dont calculate but compare patterns.
Thanks, I managed to figure it out.
And you weren't wrong about the lack of sleep!
