Forum: FPGA, VHDL & Verilog Help for a beginner.
Author: ... ... (Company: vhdl) (aqibi2000)
i need help creating a state table to produce a VHDL program.
 The system is built upon D type flip flips
The function of my program is to move between states in a sequence for
example:
9, 2 , 6, 6, 1, 5, 2 and loop back to the beginning. Each transition
needs to happen after 1 clock pulse. There is no other input to be
characterised.
So state can possible be shown as:
A = 9
B = 2
C = 6
E = 1
F = 5
but the sequence the program must take is : 9,2,6,6,1,5,2 and loop
Many thanks, also help or drawings/diagrams would be very much
appreciated.
Author: Ulrich Rinal (didididi)
Search for state machines on the internet. there are at least several
examples you could learn from.
simply post your code, which doesnt work, as you expect, by mentioning
your development environment and target.
I've read several finite state machine examples and after failing to see
how they can resemble with my system I finally gave in and decided to
register here.
The reason I am not following with the examples online is because my
system's only input is the clock, I am not feeding any other bits of
data in to dictate the path the of the next state. Compared to all the
examples I've seen they have when using a JK flip flop a J state and a K
state or D type flip flop, a D state etc.
I cannot see beyond this.
I am more concerned about creating the state diagram and state table to
then a transition table. I am well rehearsed in writing a VHDL program
but cannot get a clear understanding of how to tackle my above problem.
Much appreciated.
Author: Achim S. (Guest)
So in the examples you read an external signal decided, what the next
state should be.
i.e. something like
in state A:
if ext_signal='1' then
   next_state <= B;
else
   next_state<= C;
end if;
Well, if the next state does not depend on external signals, you can
unconditionally code the next state.
In state A you assign next_state <= B
in state B you assign next_stae <= C
No need for any other signal than CLK (maybe a reset is helpful, if you
want to start in a definded state).
In the beginning you wrote, that you want to go through the states in a
sequence like 9,2,6,6,1,5
This sequence may represent the output of your state machine, but it may
not be the sequence of the states itself. Cause it can not be, that the
following state after state 6 is in one case 6, in another case 1. This
would only be possible if you have external signals which tell you, if
the following state after 6 should be 6 or 1.
For any state, which occurs more than once in your sequence, you have to
differentiate the different occurences (you need e.g. a state 6a and a
state 6b, which may both give you the same output 6).
What's the problem: draw a state diagramm with unconditional
transistions.
Author: Schlumpf (Guest)
A statmachine without inputs is a kind of counter.
A statemachine without outputs doesn´t make any sense :-)
So I think the numbers you have listed are the outputs of your
statemachine.
The sequence 9,2,6,6,1,5,2 has seven states. Each state outputs a number
on your output-signals.
e.g.
State    Output
A        9
B        2
C        6
D        6
E        1
F        5
G        2
You can code this in the "classic" way as statemachines are coded.
But if there are no inputs you can code a simple counter alternatively.
The counter starts at "0", counts up to "6" and starts again.
You can decode the output of the counter to get the proper
output-signal.
e.g.
Counter  Output of decoder
0        9
1        2
2        6
3        6
4        1
5        5
6        2
if counter = 0 then
   output <= 9;
elsif counter = 1 then
   output <= 2;
end if;
Author: Aqib2000 .. (aqib2000)
Okay great thanks, I know that works. But what would that look like as a
circuit? To me, that looks like a counter, made of 3 jk or d type flip
flops (for counting 0 to 6 so only 3 bits), which outputs into some
logic circuit (the decoder) which outputs the final value? Because I've
tried doing that, using excitation table/ karnough maps etc. to get the
logic circuit of the decoder, but it's not been working, maybe I'm going
about it wrong?
The other way I think it can work is a counter which feeds its outputs
into a decoder into another set of flip flops which then output the
final desired values. But that seems too long-winded to be right.
I would verily appreciate all and any input you can provide.
  • [vhdl]VHDL code[/vhdl]
