Forum: FPGA, VHDL & Verilog Verilog-Range must be bounded by constant expressions
von Akshay E. (akshay_e)
module validation(test_input);
input [15:0]test_input;
reg [7:0]test_in;
integer k;
initial
begin
k=0;
end
always@(k)
begin
test_in[7:0]=test_input[7+k:k];//Range must be bounded by constant
expressions.
end
The code is partial with the same idea. The value of k changes in the
original code with maximum k value=7 (not shown here). At each change in
k, I need to copy [k+7:k] bits of test_input to test_in.
eg:
when k=1
test_in[7:0]=test_input[8:1]
when k=4
test_in[7:0]=test_input[11:4]
ERROR:Range must be bounded by constant expressions.
I need to copy 8 bits from 'test_input' to test_in.If variable is not
allowed then, what is the solution.
: Edited by User
von gurulakshmi (Guest)
please help to clear this error
Please start a new thread for a new question. Add as much information as
possible and add a useful question, at least WHAT error you want to get
rid off.
And: attach Verilog files with *.v extension.
