Forum: FPGA, VHDL & Verilog Multiple DDR3 Controllers in Stratix V
von Antony M. (antony_mat)
Hi guys i am trying to implement 2 DDR3 controllers (independent
controllers without any pll/dll/oct sharing) inside a stratix 5 device.
I use Qsys to generate the system with  PCIe Hard IP and DMA Ipcores.
What i come across is a OCT related error as below link, which altera
says as a software issue.
https://www.altera.com/support/support-resources/knowledge-base/solutions/rd03182013_916.html
But for me solution in above page not working. I am using quartus tool
ver 14.1
All example projects from altera seems to be shared DDR3 memory
controllers, which is not what i require.
Any idea guys ??
Thanks in advance...
von guest (Guest)
mhm from what I remember there are multiple configurations for the OCT
pin in the DDR3 controllers
you can set it to OCT master or slave, you'll have to make one of your
controllers a slave and connect it to the master's OCT output
the problem seems to be that you can't directly share the pin, which is
kind of analog stuff anyways, it's connected to a resistor on your PCB
and supposed to measure it's value in order to match the internal DDR3
termination resistor value...
okie.. i will try in that direction.
All sample projects of altera with shared ddr3 controllers use OCT
sharing. I thought since i am using an independend configuration,
sharing is not required.
von dedomrak (Guest)
hi Mathew
I got the same error when tried to merge 2 DDR3 + 2 RLDRAM memory
controllers in one S5 device. The problem was in RZQ sharing - I had
only 3 OCT resistors on board - 2 for each DDR and 1 shared for RLDRAM.
This particular error was emerged from next rows in my QSF file-
   set_instance_assignment -name TERMINATION_CONTROL_BLOCK
"RLDRAM2_Controller:CBank2|RLDRAM2_Bank0_example_if0:if0|altera_mem_if_o
ct_stratixv:oct0|sd1a_0"  -to mem_qk2[0] -tag
__RLDRAM2_Bank0_example_if0_p0
ct_stratixv:oct0|sd1a_0"  -to mem_qk2[1] -tag
ct_stratixv:oct0|sd1a_0"  -to mem_qk_n2[0] -tag
ct_stratixv:oct0|sd1a_0"  -to mem_qk_n2[1] -tag
Did you have anything in your QSF >
If manually edit this file you may missed this rows.
