Forum: ARM programming with GCC/GNU tools Need Help: A small problem in Clang
Author: Phong Pham (Company: HUT) (phongph)
Hi everyone,
I am having a small problem as follows, please help me:
Implement, using LLVM/Clang, to count the number of memory operations
executed in a given function (recording reads and writes of fields and
arrays elements) of C programs. Here is an example:
            int* test(int* b, int* c) {
               for (int i=0; i<10; i++) {
                   a[i] =b[i] + c[i];
               return a;
After execution of the whole program, the output of the instrumentation
should return something like this for each method: "function test: reads
= 20; writes = 10".
Thank you very much!
Author: Klaus Wachtler (mfgkw)
Are you interested in counting access to any objects or only particular
objects?
If only particular objects: you can use C++ to create a class behaving
like your array, but override operators to count usage.
The rest of your program could be kept in C as it is, usually without
modifications.
Author: gjlayde (Guest)
That's nothing to do with instrumentation: instrumenting code does not
require to change the sources.
... ok, but it would answer his question "how man reads/writes?"
But this was not the question :-)
Apart from that the numer of reads / writes can be determined by just
looking at the function: "function test: reads = 20; writes = 10".
The question is: How to change Clang so that Clang can determine the
number of reads / writes for any input (program), either by statically
analyzing the input or by instrumenting the generated code without
changing its semantics.
In general, you don't even know the input to clang as you are writing a
specific analysis or transformaton, the given source is just a sample
code to explain the issue w.r.t. changing clang.
Author: beric (Guest)
Static analysis only will not help you:
#include <stdio.h>
#include <stdlib.h>
#include <time.h>
int a[5] = { 0, }; // does this count as "write" as well? :-)
int b[5] = { 1, 2, 3, 4, 5 };
int c[5] = { 6, 7, 8, 9, 0 };
int main()
   int i, n;
   time_t t;
   /* Initialize random number generator */
   srand((unsigned) time(&t));
   /* pick a number */
   n = rand() % 5;
   /* fill a - partially */
   for( i = 0 ; i < n ; i++ ) {
      a[i] = b[i] + c[i]; // <-- now, how many times is this executed?
  return(0);
