Forum: µC & Digital Electronics Extend Flash Memory
Author: cogadh (Guest)
Hi everybody,
I am currently totally into OS dev but got very soon to memory
restrictions (not enough flash memory) on my ATmega8. Is there a way
(maybe a code trick) to extend the flash memory using an eeprom, SD,...
besides transfering to a bigger ATmega? I read some stuff about the
bootloader and SPM (though I have not fully understand everything)?!
(already using -fshort-enums, -Os in gcc but -mint8 is not an option for
me - results in creepy code crashes!)
(P.S.: don't wanna do a small sized OS or RTOS)
Author: c-hater (Guest)
1 useful
This sentence doesn't yield much sense. Querying my crystal ball I
assume the code (flash) memory of your ATmega8 is simply to small to
contain the whole nonsense shit you want to write into it.
> Is there a way
Not in the first approach.
> bootloader
Yes, "bootloader" (better: self programming) mechanisms owns the might
to virtually extend the flash. But not in the context of OS stuff. The
limited count of possible flash erase/write cycles will prohibit this
kind of usage. In the best case the flash write limits are wide enough
to "load" rarely used applications on demand (superseding other rarely
used applications).
You can do the game appr. 10.000 times, then the flash will die. Refer
datasheet if you don't trust me.
Author: fchk (Guest)
Wrong architecture!
AVR can only execute code from its internal flash. Period. And
repeatedly rewriting this flash is not an option, either. So the answer
is no.
On other architectures like ARM, MIPS (PIC32), or MPS430 (especially the
FRAM based ones) this would be no problem at all.
fchk
Author: Kilian K. (Guest)
Thanks for your responses!
Yeah, that's true! :)
I probably should switch to ARM with AVR as special purpose hardware
extension...
***CLOSED***
Author: asdfasd (Guest)
Well, you could put a virtual machine in flash which then executes byte
code from an external eeprom.  Will be slow but gets you as much memory
as you want.  Some systems using this technique: Basic STAMP,
Propeller's SPIN, ...
Author: Max (Guest)
Well you could get four times the memory by using an atmage328 instead
of atmega8
