Forum: FPGA, VHDL & Verilog read a picture into bram (code has a bug)
Author: Read a picture into bram (Guest)
There is some wrong in this code, could y help me to fix it, I want to
use it immediately.
Author: shashaxu (Guest)
library IEEE;
use IEEE.std_logic_1164.all;
use IEEE.std_logic_unsigned.all;
entity vgacore is
    port
        rgb: out std_logic_vector(5 downto 0);    -- red,green,blue colors
        addr: out std_logic_vector(14 downto 0);    -- address into video RAM
        data: in std_logic_vector(7 downto 0);    -- data from video RAM
        csb: out std_logic;        -- video RAM chip enable
        oeb: out std_logic;        -- video RAM output enable
        web: out std_logic        -- video RAM write enable
end vgacore;
architecture vgacore_arch of vgacore is
signal vsyncb:  std_logic:= '0';
signal hsyncb:std_logic:= '0';
signal clock:  std_logic:= '0';
signal reset:std_logic:= '0';
signal hcnt: std_logic_vector(8 downto 0);    -- horizontal pixel counter
signal vcnt: std_logic_vector(9 downto 0);    -- vertical line counter
signal pixrg: std_logic_vector(7 downto 0);    -- byte-wide register for 4 pixels
signal blank: std_logic;                    -- video blanking signal
signal pblank: std_logic;                    -- pipelined video blanking signal
begin
A: process(clock,reset)
begin
    -- reset asynchronously clears pixel counter
    if reset='1' then
        hcnt <= "000000000";
    -- horiz. pixel counter increments on rising edge of dot clock
    elsif (clock'event and clock='1') then
        -- horiz. pixel counter rolls-over after 381 pixels
        if hcnt<380 then
            hcnt <= hcnt + 1;
        else
        end if;
    end if;
end process;
B: process(hsyncb,reset)
begin
    -- reset asynchronously clears line counter
    if reset='1' then
        vcnt <= "0000000000";
    -- vert. line counter increments after every horiz. line
    elsif (hsyncb'event and hsyncb='1') then
        -- vert. line counter rolls-over after 528 lines
        if vcnt<527 then
            vcnt <= vcnt + 1;
        else
        end if;
    end if;
end process;
C: process(clock,reset)
begin
    -- reset asynchronously sets horizontal sync to inactive
    if reset='1' then
        hsyncb <= '1';
    -- horizontal sync is recomputed on the rising edge of every dot clock
        -- horiz. sync is low in this interval to signal start of a new line
        if (hcnt>=291 and hcnt<337) then
            hsyncb <= '0';
        else
            hsyncb <= '1';
        end if;
    end if;
end process;
D: process(hsyncb,reset)
begin
    -- reset asynchronously sets vertical sync to inactive
    if reset='1' then
        vsyncb <= '1';
    -- vertical sync is recomputed at the end of every line of pixels
        -- vert. sync is low in this interval to signal start of a new frame
        if (vcnt>=490 and vcnt<492) then
            vsyncb <= '0';
        else
            vsyncb <= '1';
        end if;
    end if;
end process;
-- blank video outside of visible region: (0,0) -> (255,479)
E: blank <= '1' when (hcnt>=256 or vcnt>=480) else '0';
-- store the blanking signal for use in the next pipeline stage
F: process(clock,reset)
begin
    if reset='1' then
        pblank <= '0';
        pblank <= blank;
    end if;
end process;
-- video RAM control signals
G:
csb <= '0';        -- enable the RAM
web <= '1';        -- disable writing to the RAM
oeb <= blank;    -- enable the RAM outputs when video is not blanked
-- The video RAM address is built from the lower 9 bits of the vertical
-- line counter and bits 7-2 of the horizontal pixel counter.
-- Each byte of the RAM contains four 2-bit pixels.  As an example,
-- the byte at address ^h1234=^b0001,0010,0011,0100 contains the pixels
-- at (row,col) of (^h048,^hD0),(^h048,^hD1),(^h048,^hD2),(^h048,^hD3).
H: addr <= vcnt(8 downto 0) & hcnt(7 downto 2);
I: process(clock,reset)
begin
    -- clear the pixel register on reset
    if reset='1' then
        pixrg <= "00000000";
    -- pixel clock controls changes in pixel register
        -- the pixel register is loaded with the contents of the video
        -- RAM location when the lower two bits of the horiz. counter
        -- are both zero.  The active pixel is in the lower two bits
        -- of the pixel register.  For the next 3 clocks, the pixel
        -- register is right-shifted by two bits to bring the other
        -- pixels in the register into the active position.
        if hcnt(1 downto 0)="00" then
            pixrg <= data;    -- load 4 pixels from RAM
        else
            pixrg <= "00" & pixrg(7 downto 2);    -- right-shift pixel register
        end if;
    end if;
end process;
-- the color mapper translates each 2-bit pixel into a 6-bit
-- color value.  When the video signal is blanked, the color
-- is forced to zero (black).
J: process(clock,reset)
begin
    -- blank the video on reset
    if reset='1' then
        rgb <= "000000";
    -- update the color outputs on every dot clock
        -- map the pixel to a color if the video is not blanked
        if pblank='0' then
            case pixrg(1 downto 0) is
                when "00" =>   rgb <= "110000";    -- red
                when "01" =>   rgb <= "001100";    -- green
                when "10" =>   rgb <= "000011";    -- blue
                when others => rgb <= "111111";    -- white
            end case;
        -- otherwise, output black if the video is blanked
        else
            rgb <= "000000";    -- black
        end if;
    end if;
end process;
end vgacore_arch;
there is some thing wrong ,could you help me to fix it
: Edited by Moderator
Did you read this:
Post long source code as attachment, not in the text
Or that:
specially the part with "VHDL code"
Do you take your car to repair and tell the mechanic: "There's something
wrong! Fix it!"
No, because then when you get the car back there may be noted on the
bill: "Fixed something!"...
Please write WHAT is wrong. And HOW you did find that out. And WHETHER
you have a test bench or not.
My VHDL files never ends with TXT. Why does yours?
BTW: I merged your two threads into one.
  • [vhdl]VHDL code[/vhdl]
