Forum: FPGA, VHDL & Verilog gnerating data flow diagrams from c code
von James Y. (Company: Naval Undersea Warfare Center) (newport_j)
I have asked this question on other Forums but to no avail. I am looking
for software preferably supported on a Linux system that can take c code
and generate data flow graphs or diagrams. I know how to generate
control flow graphs or diagrams (CFG) from c code. I just do not know
how to generate data flow diagrams from c code. That is a hard one.
Any help appreciated.
Thanks in advance.
Also, please note I said generate the diagrams from code. I know of many
software packages that can draw the diagrams once an analyst has
inspected the code and given a rough outline of the DFG. That is easy.
My code is just too complicated and too many lines to do this by
inspection ands then draw with graphic or drawing tools.
I need to generate the data flow graphs or diagrams.
Respectfully
von rs@unfoo.net (Guest)
James Yunker wrote:
> I am looking
Generating a correct and complete data flow graph probably amounts to
solving turings halting problem. in other words, it is not possible
except for special cases.
There are some tools that should be able to generate data flow graphs
from the running program, but as I won't have anything to do with "Naval
Undersea Warfare" I will help you there.
von Dose (Guest)
Perhaps some UML tools have this as reengineering function.
If you have some founded please report this in the forum.
von ah8 (Guest)
As long as you need only C it's fairly simple to build a parser for it.
I did it once (for lack of a better tool) an it is essentially just
copying the C grammar into a yacc file. Once you have that you can
extract any information the compiler has. (It's much harder to analyse
C++ since there is no yacc grammar for it. The C++ grammar is not
context free to the level, that yacc requires, I can't recall right now,
which Chomsky level that would be.)
Getting a complete data flow is tricky, though. While it's fairly simple
to extract the call hierarchy and hence the data passed down it, there
are also global variables and pointers. However, depending on your
precise requirements you can still learn a great deal about your
program.
von Kiran Barkat (Guest)
Need data flow graph
