Forum: FPGA, VHDL & Verilog Test bench I2C (vhdl)
von Javier P. (lascameador)
hi guys!
I've developed two i2c components.
u1: SlaveI2CA generic map (SLAVE_ADDR) port map(scl,sda1,clk,rst,starting1,sda2);
u2: SlaveI2CB generic map (SLAVE_ADDR) port map(scl,sda3,clk,rst,starting2,sda4);
I want to connect sda2 and sda3 with a pullup resistor (in simulation)
but i don't know how to do this.
When I write 'Z' or '0' the slave works,while it has already been
programmed ,but i don't know how to develope this function in
simulation.
any advices??
thanks ;)
Javier PA wrote:
> but i don't know how to develope this function in simulation.
Try it with Google translator:
http://www.lothar-miller.de/s9y/archives/91-Schalter-und-Bruecke.html
I would take the switch model and connect it with a pullup (='H') this
way:
 SDA_A --- Switch --- 'H' --- Switch --- SDA_B
 SCL_A --- Switch --- 'H' --- Switch --- SCL_B
Of course the switch model could be simplified to a Zero-Ohm this way:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity zeroohm is
    Port ( A : inout  STD_LOGIC;
           B : inout  STD_LOGIC);
end swbidi;
architecture Behavioral of zeroohm is
begin
  process
    variable thentime : time;
  begin
    wait on A, B until thentime /= now;
    -- Break
    thentime := now;
    A <= 'Z';
    B <= 'Z';
    wait for 0 ns;
    -- Make
    A <= B;
    B <= A;
  end process;
end Behavioral;
: Edited by Moderator
