Forum: FPGA, VHDL & Verilog VHDL project errors
Author: Saeid Syd (saeiddieas)
Hi every body,
I have 3 errors in my VHDL project,
is there any body to help me?
Project is for RF PROTOCOL.
1 useful
And now we should find this bugs on our own?
What about telling us what the toolchain (btw: which one?) tells
you?
It sounds like you give your car to a mechanic and tell him:
I have 3 problems with my car!
I already found a major design flaw:
use ieee.numeric_std.all;
USE IEEE.STD_LOGIC_ARITH.all;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
This may not cause problems up to now, but with all those libs together
you have some double definitions of data types.
My suggestion ist:
Do NOT ust the od std_logic_xxxx libs. Instead use solely the
numeric_std. It has all you will need. Your teacher should tell you
this...
And also this here is NOT a neat idea:
      id_V2 : inout std_logic_vector (15 downto 0);
      trame_moins_CS : inout natural
Use INOUT solely for real bidirectional ports. Do NOT use it for
lazyness to read back a OUT port in you design.
And also this here is not nice:
  signal adresse : integer;
  --signal trame_moins_CS : natural;
  signal taille_data : natural ;
  signal taille_trame : integer ;
You should not use an integer without a RANGE. Otherwise the simulator
cannot find a overflow...
Thanks a lot, you made my day, i'm going to check it.
  • [vhdl]VHDL code[/vhdl]
