Forum: FPGA, VHDL & Verilog 1-bit expandable magnitude comparator
Author: John (Guest)
Hey guys,
I have this Verilog project but I don't know how to start with it, or
how to do the test bench
Any help is appreciated!
Design a 1-bit expandable magnitude comparator that can be used as shown
in the pic attached.
The 1-bit expandable comparator accepts an xi input bit and a yi input
bit along with gin and ein inputs (the result of the comparison of the
more significant bits of X and Y) and produces gout and eout outputs to
indicate that X is greater than or equal to Y.
Create a Verilog behavioral dataflow model of the 1-bit comparator using
a propagation delay of 10ns for both outputs. Verify your design with a
testbench that exhaustively generates all possible input stimulus
combinations.
Once your 1-bit comparator is correct, create a 4-bit comparator as
depicted above. Create a testbench to generate all possible inputs.
Author: Klakx (Guest)
you can start with pseudo code and analyze the logic at first.
perhaps you see it, otherwise make a truth table and you receive:
g_out = x and not(y)
e_out = x and y
you also need a bigger truth table to take g_in and e_in in
consideration:
for example:
g_out = (x and not(y)) or g_in
the rest is verilog Basic knowledge
Thank you Klakx
But I'm pretty new to Verilog and this is my 2nd project. I don't have
enough knowledge yet :).
I'd be thankful if anyone could help me more explaining the requirements
and any codes that helps me starting this.
 Regards
Step 1 has absolutely nothing to do with any HDL: pick out one of
those comparators. It has 4 inputs and 2 outputs. Set up a truth table
for each of the outputs. When you have done this, then maybe one can
help you to transfer your truth table to Verilog...
As a little hint: the truth table for e out looks like this
  ein gin  x   y   eout
   0   X   X   X    0    |  previous stage is unequal --> total result is unequal
   1   0   0   0    1
   1   0   0   1    0
   1   0   1   0    0
   1   0   1   1    1
   1   1   X   X   Error |  not possible! input can't be greater and equal the same time
What a stupid requirement. In real life you must never use a
"pseudo-delay" in a functional description. Or: try it and remember
me...
John just make a first try with testbench, your component and the
pseudo-code and then we can help you.
Author: guest (Guest)
you must be in my ECE171 class... this project SUUUCKS!
Hmmmmm, let me say it this way: YOU wanted to become an electronics
engineer. And that here is a (fairly easy) job for this kind of
business. It will get much more difficult later on...
: Edited by Moderator
OK... this material is fun and gratifying... procrastinating and
stressing is what sucks... can I post here here for advice on this same
project?
guest wrote:
> can I post here here for advice on this same project?
Why not?
Now you and John can try to show at least a little peace of anything
instead of only saying "Do my homework"...
Thank you... I have a module built for my one bit comparator... kinda
stumped on the test bench tho. here's what I have so far:
module oneBitComparator (X, Y, Ein, Gin, Eout, Gout);
input X, Y, Ein, Gin;
output Eout, Gout;
assign Eout = (X & Y) | (~X & ~Y);
assign Gout = (X & ~Y);
endmodule
What about the inputs gin and ein?
I cannot see them in your assignments, but they are in my truth table...
BTW pls do it this way:
[c]
  verilog code
[/c]
I really wasn't sure what do do with those inputs on the 1-bit
comparator... how would here be "equal or greater" (Gin, Ein) inputs
when there is no previous instance of the module?
I'm sorry but i'm very new to this, and I'm getting a little frantic
It was the same for me. I did not know anything about this project. Then
I started thinking...
> how would here be "equal or greater" (Gin, Ein) inputs when there is no
Then the "previous" result is neither greater nor is it equal. So both
of them will be '0'.
Ok... was i mistaken in my assumption that x and y would be my control
bits?
also i was slightly confused by your ruth table showing ein true for all
x and y
i'm sorry, i meant to say select bits
Author: Lattice User (Guest)
It should be set to equal, otherwise the end result can't be equal at
all.
I realized that almost simultaneously as you posted it; Thank you SO
much for the confirmation!!
I'm thinking I need to redraw my truth table to account for all possible
combinations of ein and gin, then rewrite my boolean expressions
> all.
Right, this can easily be seen in the truth table above. I should have
had av second look...
here's the truth table i came up with:
Am i correct in assuming that when gin is true gout will be true as
well?
the Boolean equation I came up with is
Gout= ~Ein * Gin + Ein * ~Gin  x  ~y
Eout= Ein * ~Gin * ~x * ~y + Ein * ~Gin  x  y
sorry i kinda botched that... this is correct
Gout= ~Ein * Gin + Ein * ~Gin  x *  ~y
Eout= Ein * ~Gin * ~x * ~y + Ein * ~Gin *x*y
Author: Kay (Guest)
you seem to be missing 1001 on your truth table
well my truth table and Gout equation was wrong, but i think i fixed it.
output Eout, Gout;
 assign Eout = (Ein & ~Gin & X & Y) | (Ein & ~Gin & ~X & ~Y);
 assign Gout = (~Ein & Gin & X) | (Ein & ~Gin & ~Y) | (Ein & ~Gin & X & ~y);
endmodule
thanks for pointing that out kay. I did catch that, eventually
guest wrote in post #4040647:
> seems to be leaving out some of my asterisks. weird
Use the c and /c tags to hinder the forum sw from interpreting the * as
"bold font"...
does my module look sound? it compiles just fine; working on the test
bench now
anyone?
Maybe then someone could explain how I can connect the Gout and Eout
outputs to the next cascaded Gin and Ein inputs with wires?
This is the code for my 4 bit comparator so far i need to figure out how
to connect the Gout/Eout to Gin/Ein via wires. any help would be greatly
appreciated...
module fourbitComparator(X, Y, Ein, Gin, Eout, Gout);  //maybe
 input [3:0] Ein, Gin;
 input [3:0] X, Y;
output Eout, Gout;
 wire Xeq0, Xeq1, Xeq2, Xeq3, Xg0, Xg1, Xg2, Xg3;
 oneBitComparator com0(Ein[0], Gin[0], X[0], Y[0], Xeq0, Xg0);
 oneBitComparator com1(Ein[1], Gin[1], X[1], Y[1], Xeq1, Xg1);
 oneBitComparator com2(Ein[2], Gin[2], X[2], Y[2], Xeq2, Xg2);
 oneBitComparator com3(Ein[2], Gin[2], X[3], Y[3], Xeq3, Xg3);
 assign #10 Eout = (Xeq0 & Xeq1 & Xeq2 & Xeq3);
 assign #10 Gout = (Xg3 | (Xg2 & Xeq3) |
 (Xg1 & Xeq3 & Xeq2) |
(Xg0 & Xeq3 & Xeq2 & Xeq1));
endmodule
Author: Dornman (Guest)
Have you written the testbench already?
No, could you help with the testbench plz
I think we need a for loop in it
for (i = 0; i < 16; i = i +1) begin
   vector = vector + i;
end
something like this, but start with a simple testbench at first to check
one or two Signal combinations.
  • [vhdl]VHDL code[/vhdl]
