Forum: FPGA, VHDL & Verilog creating and ALU in verilog
Author: Harman Litt (Guest)
I was wondering if it were possible to have if statements as so for the
ALU I am trying to build. I am passing values from a datapath test bench
to a datapath, from the datapath into the ALU, and from the ALU back to
the datapath. What i am trying to do is create a control unit which will
only pass values through a certain component if the corresponding
control_ALU is activated.
here is my verilog code :
module ALU (
 input en_ALU, clk_ALU,
input [31:0]  inputA, inputB, control_ALU,
output [31:0] resultc
wire [31:0] res_out;
always @(control_ALU)
begin
        if(control_ALU[1])  begin
    andLogic  andLogic_component(
                                            .dataA (inputA),
                                            .dataB(inputB) ,
                                            .resultA (res_out));
end
 if(control_ALU[2]) begin
negate m0(
.inputnegate    (inputA),
.resultnegate   (res_out)
    end
end
reg64bit z(.clk(clk_ALU) , .clr(clr), .enable(en_ALU), .inputd(res_out),
.outputq(resultc));
endmodule
Author: vincent himpe (Guest)
Here is how i typically make ALU. I've done a number of custom
processors this way.  Note : Verilog 2001 syntax and i do make use of
command scheduling as per the official Verilog spec ( very few people
know/use scheduling but all synthesizers support it : Quartuse, ISe ,
Synopsys )
module mini_alu( input [31:0] a,b ,
                 input [7:0] opcode,
                 input reset,
                 output [31:0] x )
`define opcNOP    8'd0
`define opcAND    8'd1
`define opcOR     8'd1
`define opcBWANDa  8'd2
`define opcBWANDb  8'd2
.... other opcodes
always_comb(begin)
case (opcode)
    `opcNOP : output = 32'h0;
    `opcAND : output = a & b;
    `opcBWANDa : output = &a;
    default :  output = 32'b0;
endcase
if (reset) output <= 32'hDEADBEEF
end
endmodule;
vincent himpe wrote:
drat ! typo's fixed
> Synopsys )
                  input [7:0] opcode,
                  input reset,
                  output [31:0] x )
 `define opcNOP    8'd0
 `define opcAND    8'd1
 `define opcOR     8'd2
 `define opcBWANDa  8'd3
 `define opcBWANDb  8'd4
 // .... other opcodes
> always_comb begin
 case (opcode)
 endcase
 end
 endmodule;
[/code]
  • [vhdl]VHDL code[/vhdl]
