Forum: FPGA, VHDL & Verilog VHDL Audio Codec
von Kody H. (Company: Student) (kodyhaugli)
Hello,
I am doing a project for one of my 4th year classes for Electrical
Engineering which is based around active noise cancelation. I have a
Digilent ZYBO Zynq 7000 Development Board and run the Vivado program.
Our board has a mic in port and a headphone out port and what I am
trying to do is build a codec for an incoming noise signal although I am
having some trouble starting out. I have came across some example IP
block diagrams from the Digilent website that deals with audio and video
codec, but I can't seem to access the VHDL code.
I was wondering if anyone would have some information on where I could
find some good starting tips/code for an audio codec?
As well I was wondering if anyone is familiar with Vivado and System
Generator and could explain how System Generator generates IP from
simulink block diagrams.
Thank you.
von freelancer (Guest)
forget it
simulink and system generator is a world which requires about two years
to learn about and vivado is also not self explaining.
you are running in too large steps - why don't you start with the maths
and algorithms behind noise cancelling?
an audio codev in vhdl is not required in any way, since this should be
done in hardware. you only need some configuration of the codec and an
input output system with your code in between.
von uwe (Guest)
You need to read:
http://www.analog.com/media/en/technical-documentation/data-sheets/SSM2603.pdf
and page 23 of
http://www.digilentinc.com/data/products/zybo/zybo_rm_b_v6.pdf
The audio codec itself has an DSP inside. You have to configure the
Codec so you get audio data in the FPGA. You have to implement a I2S or
I2C statemachine.
von Valko Z. (hydravliska)
You should start with simple tasks as freelancer suggested. The first
thing you may try is to output something on the "headphone out" port.
Then you may try to sample the input coming over the MIC port. Then you
may try to speak on the MIC and output it on the HEADPHONE port.
This sounds simple but you still require to generate/extend your design.
Basics such as clock generation and synchronizing all the stuff and so
on are things which you need to take care of.
Once you have the pipeline MIC_IN -> FPGA -> HEADPHONE_OUT it will be
much easier for you to add a processing module to it.
Regards
