Forum: FPGA, VHDL & Verilog Verilog Code for 4 32 bit numbers sorting in Ascending order
von Chaitanya B. (Company: University of Utah) (chaitanya)
Hello,
Can some one give verilog design and basic verilog code for designing
four 32 bit numbers sorting in Ascending order. Thanks.
We are NOT doing anyones homework. Lets try it that way: YOU start with
something and we discuss what's wrong with that and what's ok.
Lothar,
This is not my home work problem. I tried to solve using For loops like
how we will implement in C. but what I read is if we use for loops
inside the verilog code, synthesis tool will not generate a best design
net list, leading to more area of the circuit. Apart from that idea,
other designs are not striking to me. So posted, thinking that I may get
better design ideas from experienced guys. Thanks.
It that way: a loop in a HDL (VHDL, Verilog,...) results in a
combinatoric design. Its a little bit demanding in resources, but its
easily written down. So my first attempt would be to write it down the
straight forward style, and if its "too slow" or "too big" then I would
start thinking...
I cannot help you with Verilog, because I'm VHDL, but maybe this gives
you a starting point:
http://www.lothar-miller.de/s9y/archives/78-Bubblesort.html
von Venkatesh (Guest)
//Bubble sort Version 1 - 06/17/2016
module priority_queue (clk,reset,d_en,d_in, d_out);
    parameter n = 10;         //Number of inputs
    parameter s = 32;         //Size of the register
input clk;
input reset;
input [s-1:0] d_in;
input d_en;
output [s-1:0] d_out;
reg [s-1:0] d_out;
reg [s-1:0] reg_in [n-1 :0];       //Input registers
reg [s-1:0] reg_out [n-1:0];       // Output registers
reg [5:0] addr_in;                 //Input register data pointer
reg [5:0] addr_out;               // Output register data pointer
reg d_sort;
reg [5:0]sort_count;
integer i,j;
   always @ (posedge clk)
   begin
       if(reset)
       begin
           for(i=0; i<n; i=i+1)
           reg_out [i] <= 32'd0;
           addr_in <=6'd0;
           addr_out <=6'd0;
           d_out<= 32'd0;
        d_sort<=1'b0;
         sort_count <=6'd0;
       end
       else if (d_en)
       begin
           reg_in[addr_in] <= d_in;
           addr_in <= addr_in +1'b1;
           addr_out <= 6'd0;
       end
       else if (!d_en)
       begin
           for (j=n-1; j>=1; j=j-1)
           begin
               for (i=0; i<= n-2; i=i+1)
               begin
                   if(reg_in[i] > reg_in[i+1])      //Comparison
operation
                   begin
                       reg_in[i] <= reg_in[i+1];    // Swapping
                       reg_in[i+1]<= reg_in[i];     // swapping
                   end
                   reg_out[i] <= reg_in[i];         //Transfering input
reg value to output registers.
               end
               sort_count <= sort_count +1'b1;
           end
           if( sort_count == (n-1))
           d_sort <=1'b1;
       end
       if(d_sort)
       begin
           d_out<= reg_out[addr_out];
           addr_out <= addr_out + 1'b1;
           addr_in <= 6'd0;
       end
   end
endmodule}
reg [s-1:0] d_out;
reg d_sort;
integer i,j;
   begin
       if(reset)
       begin
           addr_in <=6'd0;
           addr_out <=6'd0;
           d_out<= 32'd0;
        d_sort<=1'b0;
         sort_count <=6'd0;
       end
       else if (d_en)
       begin
           addr_out <= 6'd0;
       end
       else if (!d_en)
       begin
           begin
               begin
operation
                   begin
                   end
               end
           end
           d_sort <=1'b1;
       end
       if(d_sort)
       begin
           addr_in <= 6'd0;
       end
   end
endmodule
input clk;
input reset;
input [s-1:0] d_in;
input d_en;
reg [s-1:0] d_out;
reg d_sort;
integer i,j;
   begin
       if(reset)
       begin
           addr_in <=6'd0;
           addr_out <=6'd0;
           d_out<= 32'd0;
        d_sort<=1'b0;
         sort_count <=6'd0;
       end
       else if (d_en)
       begin
           addr_out <= 6'd0;
       end
       else if (!d_en)
       begin
           begin
               begin
operation
                   begin
                   end
               end
           end
           d_sort <=1'b1;
       end
       if(d_sort)
       begin
           addr_in <= 6'd0;
       end
   end
endmodule
von k.n.v.sriram (Guest)
verilog code for merge sort in parallel algorithm
von omganeshkunal@gmail.com (Guest)
can you send verilog code in quick sort
von BMmax (Guest)
Pleaze
i need veirlog code for quick sort
can any one share it with me
thanx
von BMmax (Guest)
Pleaze
thanx
von Shiv K. (Company: CETPA) (shivk23)
#include <stdio.h>
main()
        int A[20], N, Temp, i, j;
        printf("\n\n\t ENTER THE NUMBER OF TERMS...: ");
        scanf("%d",&N);
        printf("\n\t ENTER THE ELEMENTS OF THE ARRAY...:");
        for(i=1; i<=N; i++)
                scanf("\n\t\t%d", &A[i]);
        for(i=1; i<=N-1; i++)
                for(j=i+1; j<=N;j++)
                        if(A[i]>A[j])
                                Temp = A[i];
                                A[i] = A[j];
                                A[j] = Temp;
        printf("\n\tTHE ASCENDING ORDER LIST IS...:\n");
        for(i=1; i<=N; i++)
                printf("\n\t\t\t%d",A[i]);
von Dinesh (Guest)
Can any one help in writing test bench for it
von C M KALAISELVI (Guest)
Can anyone tell me the verilog code for finding an element in a sorted
array list
von Gustl (Guest)
C M KALAISELVI wrote:
> Can anyone tell me
Pls start a NEW thread for a NEW question!
