Forum: FPGA, VHDL & Verilog Traffic Light VHDL , counter
von Gabriel (Guest)
Please some help with this code, I dont know where is the problem, is
giving me these errors:
Error: Node instance "TLong" instantiates undefined entity "OneShot"
Error: Node instance "TShort" instantiates undefined entity "OneShot"
here is the code...
library ieee;
use ieee.std_logic_1164.all;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity TimerCircuits is
port (LongTrig, ShortTrig, Clk: in std_logic;
TS,TL : buffer std_logic);
end entity TimerCircuits;
architecture TimerBehavior of TimerCircuits is
component OneShot is
port (enable, Clk : in std_logic;
    Duration : in integer range 0 to 25 ;
    QOut : buffer std_logic );
end component OneShot;
signal SetCountLong, SetCountShort: integer range 0 to 25;
begin
SetCountLong <= 25;
SetCountShort <=4;
TLong:OneShot port map (enable=>LongTrig, Clk=>Clk, Duration=>SetCountLong, QOut=>TL);
TShort:OneShot port map (enable=>ShortTrig, Clk=>Clk, Duration=>SetCountShort, QOut=>TS);
end architecture TimerBehavior;
: Edited by Moderator
Gabriel wrote:
> here is the code...
It that all of the code?
The entity "OneShot" is not known here in this module. You must
implement an entity "OneShot" and include it in the build process.
> is giving me these errors:
What toolchain give you that error?
Next time try this:
[vhdl]
  VHDL code
[/vhdl]
