Forum: FPGA, VHDL & Verilog analogue-to-digital decoder
von hossam (Guest)
hello
please I am looking for a VHDL description, for analogue-to-digital
decoder, with analog input, and an output of 8 bits. if someone have
information . thanks
What do you need this "converter" for? What is a "analog value"? You
know that you cannot synthesize such a description on a FPGA?
von hossam (Guest)
hello
thank you for your help. Therefore the analog value is a voltage between
40 and 200 mV. I'm not really a profissionnel in the field.
I want this converter to find two numerical values for comparison, if
not. can I compare two voltage without converting them.
von Lattice User (Guest)
hossam wrote:
> hello
Yes you can, all what you need is an OPAMP with sufficient gain.
You can't implement an analog circuit directly with VHDL in a FPGA.
Some FPGA come with a low speed ADC (just like the one in many
microcontroller) which you can access from VHDL.
You can also implement a sigma delta ADC in a FPGA using VHDL, but this
also requires an external comparator (OPAMP).
With a comparator you can easily determine, which one of two voltages
is higher...
