Forum: FPGA, VHDL & Verilog Large arrays
von Saltwater (Guest)
I was experimenting with building large arrays, but after a substantial
compilation time there is hardly a tax on logic. It made me wonder where
the registers have gone? And ultimately what is wisdom in builing large
arrays?
First read your post as if the heck you don't know anything about your
toolchain, your target and your actual problem. To say it short: read it
as if you were me (or anybody else on the world). Then answer this
question: is it possible to give a senseful anwer? No? Right!
Let me just assume you use some kind of HDL and you want to target a
FPGA, then it may be that your huge array has no connection to the
outer world, and therefore it is just optimized away...
: Edited by Moderator
Im using Verilog on a Cyclone V FPGA, "reg [32:0] Array [0:524287];"
Referencing the array in the main file. And then pointing to it once,
And instance wire module to point from it.
To try to try what you said out I made the pointers work, but since im
constrained to the pins, I cant output my 33bit array just yet. Assuming
it gets optimised out pointing to the register it is pointing to now..
So the result is "296 / 32,070 ( < 1 % )"
But.. In general "if it synthesized" correctly would it be feasible to
bank on using about 4x (32/24) x 524287 of ram on board? And still
getting away with some DSP?
Saltwater wrote:
> would it be feasible to bank on using about 4x (32/24) x 524287 of ram
> on board?
Sounds linke some 20MBits. Does your FPGA have so much RAM inside?
Even the biggest Cyclone V seems to have "only" 12MBits...
http://www.altera.com/devices/fpga/cyclone-v-fpgas/overview/cyv-overview.html
http://www.altera.com/devices/fpga/cyclone-v-fpgas/overview/cyv-overview.html#table9
I see, it's ~4Mbit for the SE SoC model. It does look great on paper. Ah
well maybe later I can dedicate the proper hardware to it. Memory
controller it is then..
