Forum: FPGA, VHDL & Verilog LED intensity
von Oer P. (Company: None) (ponta)
Hello, I got an assignment to make LED lights change intensity, by
switching 4 switches on pegasus board. I got some code but I don't think
it's good. Can you check it or improve it? Thanks
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity PWM is
  generic
    sd        : unsigned(11 downto 0) := X"C35" -- 3125 in hex
  port
    clock     : in   std_logic;
    switches  : in   unsigned(3 downto 0);
    pwm       : out  std_logic
end PWM;
architecture behave_PWM of PWM is
  signal counter : unsigned(15 downto 0);
begin -- architecture
  pwm_proc: process (clock)
  begin
    if (counter <= switches*sd) then
      pwm <= '1';
    else
      pwm <= '0';
    end if;
30
    if (counter >= 50000) then
31
      counter <= (others => '0');
32
    else
33
      counter <= counter + 1;
34
    end if;
35
  end process;
36
37
end behave_PWM;
Oer Pdw wrote:
> I got some code but I don't think it's good.
You are right. This will work in a simulator at best. But you will never
ever get it on hardware.
The major drawback is the missing clock inside the process. It is not
enough to have the clock in the sensitivity list. Look how all the
others do it...
: Edited by Moderator
The problem is that everyone has different task so I can't check
Can you help me?
What should this sentence say?
What I said is: there is no clock in your design! But each counter needs
a clock because its built of flipflops. Have a look how everybody on the
world describes a counter. There must be a rising_edge() or a 'event
in your code!
Is it good now?
library ieee;
entity PWM is
  generic
    sd        : unsigned(7 downto 0) := X"C3" -- 195 in hex
  port
    switches  : in   unsigned(7 downto 0);
    pwm       : out  std_logic
end PWM;
  begin
if(clock'event and clock='0'") then
      pwm <= '1';
    else
      pwm <= '0';
    end if;
30
31
32
33
    else
34
35
end if;
36
    end if;
37
  end process;
38
39
end behave_PWM;
Oer Pdw wrote:
> Is it good now?
There is a syntax error in it, but the concept is ok.
> Is it good now?
Take a little test bench and check it out...
