Forum: FPGA, VHDL & Verilog Memory issues
Author: Compstomp (Guest)
Altera forum is dead as ever on this issue.. I have a DDR3 controller,
but in order to test it i have to get the Quartus to interface to my
DDR3 stick. As in connect the physical pins to my project. This it does
not do for some reason I cant really put my finger on. But I get "those"
warnings. Could this be due to termination IE can be ignored or?
Error (14566): Could not place 2 periphery component(s) due to conflicts
with existing constraints (2 pin(s))
  Error (175020): Illegal constraint of pin to the region (89, 69) to
(89, 80): no valid locations in region
    Info (14596): Information about the failing component:
      Info (175028): The pin name: WE // Write enable
    Info (14597): No legal location could be found for this component
out of 1 considered location(s).  Reasons why each location could not be
used are summarized below:
      Error (184016): There were not enough single-ended output pin
locations available (1 location affected)
        Info (175029): C28 // Exists
      Info (175015): The I/O pad WE is constrained to the location
PIN_C28 due to: User Location Constraints (PIN_C28)
        Info (14709): The constrained I/O pad is contained within this
pin
  • [vhdl]VHDL code[/vhdl]
