Forum: µC & Digital Electronics Replacing an unknown DC-DC converter
von Martin (Guest)
Hello,
i got a not working video transmitter from a friend. He used a 12V
supply, but the part need a 5 V supply. After some measurement i found
out that the fuse is ok, but there are three dcdc-converter which aren't
working.
The three parts have each an inductor for filtering there outputs and
after i desoldered it i could measure that the parts which are supplied
ok.
Now i only need to replace the parts, but i didn't find the name of the
IC. It is labeled with : "CB=DG", "81R".
The part has a QFN-16 case with thermal pad.
After i searched a bit and looked at some distributors i didn't find the
part, has someone an idea what's the name of the part is ?
Regards,
Martin
von Easylife (Guest)
I guess it's a RT8058
http://www.richtek.com/product_detail.jsp?s=285
Cheers.
RT8058GQW to be precise.
http://www.rom.by/files/Richtek_Marking_Code.PDF
"CB=" matches, pinout looks good too.
5.5V max. input voltage explains damage at 12V.
von Martin (Guest)
Hello,
thanks for your idea, i think it could be this part.
The marking is not at the datasheet but i contact richtek.
Regards,
Martin
von Martin (Guest)
Hello again,
thanks for the second post, yes this should be right, thank you very
much.
Regards,
Martin
