Forum: FPGA, VHDL & Verilog CIC filter decimator on VHDL
Author: Dmtry Karlin (Company: stc) (desmond_breezey)
Hi to all again.
It is a structure with 2 steps : CIC filter decimator and FIR after CIC.
A simulation shows nothing signals on out bus of the structure. I have
no some ideas why. Can someone say what happening?
: Edited by User
1 useful
Of course it schows something! What? A 'U' known as "uninitialized"?
> I have no some ideas why.
When you use a reset signal to assign start values (instead of
initilizing them at the declaration), then you must assert this reset
signal at the beginning of your test bench...
With the simulator you can dig into each signal of each module. Then
you can easily see, whats going on and whats going wrong...
: Edited by Moderator
I did it so:
  signal reset : std_logic :='1' ;
  res: process
  begin
  for i in 0 to 100 loop
  wait until clk='1' and clk'event;
  end loop;
  reset <='0';wait;
  end process res;
Also, i created a new output signal (it is called trans).
 trans <= transfer
transfer - a signal with information from output bus of CIC. In the
simulator i saw that trans have status "U", and on output bus i have
nulls. What is it mean? Is the CIC wrong? But i took an example from the
book, and FIR filter also must be done correctly, because i did FIR some
times ago and it was done correctly, and i just have taken my previous
code with the necessary changes.
: Edited by User
Oh, i understood.
I think you mean somethink like this:
signal filter_in : std_logic_vector(7 downto 0):= (others =>'0');
: Edited by User
  • [vhdl]VHDL code[/vhdl]
