Forum: FPGA, VHDL & Verilog Serial ports
von Leiser H. (leiserhartbeck)
Hello Sir,
I am working on a system which require 8 serial ports. Most of the FPGA
boards have at the maximum of two serial ports. Can I implement other
serial ports on the FPGA using the IO pins. How many serial ports can be
implemented? What additional circuitry will I require to interface it
with other systems.
Reagrds
Leiser
Leiser Hartbeck wrote:
> Can I implement other serial ports on the FPGA using the IO pins.
Obviously your "serial port" is a RS232 port and in a FPGA it is an
ordinary IO pin ...
> How many serial ports can be implemented?
That depends on the size and the pincount of your FPGA. But you wlii be
able to pack at least fifty to hundred RX/TX ports even in the smallest
FPGA nowadays.
> require to interface it with other systems.
If your "serial port" is a RS232 port, then you will need a driver/level
shifter like the MAX232...
von René D. (Company: www.dossmatik.de) (dose)
Yes, it is possible to wirte an Uart in a hardware description language
and put it 8 time in a design.
The question is, how is your dataflow?
After, you will have 8 latches with the received values. What is doing
with this registers?
Do you what to calculate something or send this the anohter IN/Output
port?
Hello,
I have 8 differrent sensors and actuators which need to be controlled
over RS232/485/422. The data from sensors need to be read and passed to
either a softcore processor or a seprate processor for algorithms to
work. The output from the processor needs to directed to actuators. How
can this be implemented. Can I do some basic sorting and pre processing
of data on FPGA and then transmit it forward?
Regards
Leiserhartbeck
von Duke Scarring (Guest)
Did the sensors alwaya send or only on request?
Duke
> Regards
> Leiserhartbeck
Yes you can proprocessing the Data.
But you have to know FPGA development need more time as software
develoment.
If you want to try different algorithm, this is simplier to solve in
software.
Hello,
My major algorithms run on software and on main processor. Is there a
place where I can get schematic diagrms of boards utilising FPGA with
processor which I can use for designing my own board?
Regards
Leiserhartbeck
