Forum: FPGA, VHDL & Verilog Improving my code!
von Enrique Perez (Guest)
Hello buddys!
I am working with a image sensor which delivers 4 pixels (12 bits/pixel)
every system clock.
The pixel output of the sensor is 6 Lines x 2112 pixels. And I want to
throw away some pixels per line according to the parameter SHIFT_COL.
For example,
- if SHIFT_COL = 1, the 1st pixel of every line should be skipped
resulting 2111 pixels.
- if SHIFT_COL = 2, the 2 first pixels of every line should be skipped
resulting 2110 pixels
- and so on...
Here is the code that I have already programmed. But I think that it
could be a better coding for this issue. Any suggestion?
  -- Valid Pixels Management:
      -- Receiving 4 pixels on every clock cycle and skip some of them
    -- according to the parameter SHIFT_COL
    SHIFT_DAV  <= '0';
    -- New "4pixels" or The limit number of pix is not achived!
    if VID_I_DAV = '1' or (SHIFT_CNT > 0 and (SHIFT_CNT < 2112+(4*unsigned(SHIFT_COLr)))) then
      VID_I_CNT <= VID_I_CNT + 4;
      SHIFT_SEL    <= SHIFT_SEL + 1;
      -- Binning 6x6 => Max. 10 pixels to shift!
      if FPGA_MODE_l = "100" then
        case SHIFT_COLr is
          when x"0000" => -- No shifting
            if SHIFT_SEL = 0 then
              SHIFT_DATA_REG <= VID_I_DATA;
              SHIFT_DAV  <= '1';
              SHIFT_SEL  <= (others=>'0');
              SHIFT_CNT <= SHIFT_CNT + 4;
            end if;
          when x"0001" => -- Shifting 1 column
              SHIFT_PIX_REG1  <= VID_I_DATA(23 downto 12);
              SHIFT_PIX_REG2  <= VID_I_DATA(35 downto 24);
              SHIFT_PIX_REG3  <= VID_I_DATA(47 downto 36);
            elsif SHIFT_SEL = 1 then
              SHIFT_DATA_REG <= VID_I_DATA(11 downto 0) & SHIFT_PIX_REG3 & SHIFT_PIX_REG2 & SHIFT_PIX_REG1;
              SHIFT_DAV <= '1';
30
31
            elsif SHIFT_SEL = 2 then
32
33
34
35
36
              SHIFT_DAV <= '1';
37
              SHIFT_SEL   <= x"1";
38
39
            end if;
40
          when x"0002" => -- Shifting 2 columns
41
42
              SHIFT_PIX_REG1 <= VID_I_DATA(35 downto 24);
43
              SHIFT_PIX_REG2 <= VID_I_DATA(47 downto 36);
44
45
46
47
              SHIFT_DATA_REG <= VID_I_DATA(23 downto 0) & SHIFT_PIX_REG2 & SHIFT_PIX_REG1;
48
              SHIFT_DAV <= '1';
49
50
51
52
53
54
              SHIFT_DAV <= '1';
55
              SHIFT_SEL   <= x"1";
56
57
            end if;
58
          when x"0003" => -- Shifting 3 columns
59
60
              SHIFT_PIX_REG1 <= VID_I_DATA(47 downto 36);
61
62
63
              SHIFT_DATA_REG <= VID_I_DATA(35 downto 0) & SHIFT_PIX_REG1;
64
              SHIFT_DAV <= '1';
65
66
67
68
69
              SHIFT_DAV <= '1';
70
              SHIFT_SEL   <= x"1";
71
72
            end if;
73
74
          when x"0004" => -- Shifting 4 columns
75
76
77
              SHIFT_DAV  <= '1';
78
              SHIFT_SEL  <= x"1";
79
80
            end if;
81
          when x"0005" => -- Shifting 5 columns
82
83
84
85
86
87
88
89
90
91
              SHIFT_DAV <= '1';
92
93
            elsif SHIFT_SEL = 3 then
94
95
96
97
98
              SHIFT_DAV <= '1';
99
              SHIFT_SEL   <= x"2";
100
101
            end if;
102
          when x"0006" => -- Shifting 6 columns
103
104
105
106
107
108
109
110
              SHIFT_DAV <= '1';
111
112
113
114
115
116
              SHIFT_DAV <= '1';
117
              SHIFT_SEL   <= x"2";
118
119
            end if;
120
          when x"0007" => -- Shifting 7 columns
121
122
123
124
125
126
              SHIFT_DAV <= '1';
127
128
129
130
131
              SHIFT_DAV <= '1';
132
              SHIFT_SEL   <= x"2";
133
134
            end if;
135
136
          when x"0008" => -- Shifting 8 columns
137
138
139
              SHIFT_DAV  <= '1';
140
              SHIFT_SEL   <= x"2";
141
142
            end if;
143
          when x"0009" => -- Shifting 9 column
144
145
146
147
148
149
150
151
152
153
              SHIFT_DAV <= '1';
154
155
            elsif SHIFT_SEL = 4 then
156
157
158
159
160
              SHIFT_DAV <= '1';
161
              SHIFT_SEL   <= x"3";
162
163
            end if;
164
          when x"000A" => -- Shifting 10 columns
165
166
167
168
169
170
171
172
              SHIFT_DAV <= '1';
173
174
175
176
177
178
              SHIFT_DAV <= '1';
179
              SHIFT_SEL   <= x"3";
180
181
            end if;
182
          when others => null;
183
        end case;
184
      end if;
185
    end if;
Thanks anyway!
: Moved by Moderator
I moved your thread from the German (uc.net) to the Englisch spoken
forum (embdev.net).
Enrique Perez wrote:
> But I think that it could be a better coding for this issue.
For sure. This code looks like a copy-and-paste structure.
> Any suggestion?
DON'T_WRITE_ALL_THE_NAMES_IN_UPPERCASE_LETTERS! IT_MAKES_THE_ CODE
NEARLY_UNREADABLE!
> And I want to throw away some pixels per line according to the parameter
> SHIFT_COL.
> For example,
> resulting 2110 pixels - and so on...
I would do this "skipping" during reading the line. Then its very easy:
just don't read a value.
If you already read the line, then Skipping would be just a
recalculation of the offset for accessing the data.
Ok I am sorry, I would not know where to place it
The problem is that I need to buffer a complete line in order to make
the skipping of the pixels, and I don't have enough space in the FPGA to
implemente a FIFO o RAM to buffer a complete line...
Any other suggestion?
Thanks
Why that?
> and I don't have enough space in the FPGA to implemente a FIFO o RAM to
Why not?
>> output of the sensor is 6 Lines x 2112 pixels ... (12 bits/pixel)
That means 6x2112x12 = 152064 bit. Even an ancient XC3S200 has 221,184
bits of RAM...
Now the FPGA is almost 93%. I think I can't make that
 implementation in
 the FPGA.
 Anyway in the initial post ( I am very sorry). What I want to have is
 always 2112 pixels. So when for example, SHIFT_COL = 1 and the input of
 the sensor is so:
          Input                                      Output
 Pixel1 Pixel2 Pixel3 Pixel4           Pixel1   Pixel2   Pixel3   Pixel4
    0     1      2       3               1        2         3       4
    4     5      6       7               5        6         7       8
    8     9      10      11      =>      9        10        11      12
  2108   2109   2110  2111              2109     2110    2111    2112
 As you can see the amount of pixels is always the same: 2112.
 A lot of thanks
: Edited by Moderator
von -gb- (Guest)
You want to shift all values by 1 to the left?
And the leftest value from the next line N becomes the rightes in the
line (N-1)?
What du you want to do with the Values? I think you could store the
values in an BRAM and just offset the readaddress by one or two. The
missing additional values in line 6 at the right can be stored
seperatly.
No really, what I want to do is throw away the values according to the
parameter SHIFT_COL. But alway I have to deliver 2112 pixels.
In my previous post, you can see that the incoming data are 4 pixels in
parallel and I am capturing 2112 pixels always. If for example the
content of every pixel is directly the number of the pixel (this is
something theoretical, in reality I am going to have the pixel value
coded in 12 bits), when SHIFT_COL = 1, I have to throw away the first
pixels of the 4 incomming paralles pixels. When SHIFT_COL=2, I have to
throw away 1st and 2nd pixel of the 4 incomming parallel pixels and so
son...But always I have to provide a packet of 2112 pixels (You can
shift the window of the sensor until 2202 pixels).
> but always I have to provide a packet of 2112 pixels
To whom? And by which means? What interface? Do you have "to deliver" it
parallel? Or with a serial protocol pixel by pixel?
Thousands of questions. No one of them answered...
Let me say it that way: a beginner will need a much bigger FPGA due to
not using properly components inside it. The far I can see it you can
easily reduce that footprint: let me simply assume there is a big
monster array somewhere in the not posted code...
Are those 93% with or without RAM blocks?
I have to provide 2112 pixels to the PC via Ethernet!
The sensor is delivering in parallel 4 pixels. Then I make a data
processing where I have to do the sikiping of the pixels and a binning
later.
It is 93% using 3 RAMs to store pixel to make the data processing.
von Sigi (Guest)
Transmitting Pixels via Ethernet means: a kind of serial process.
Receiving Pixels from Camera 4 Pix/Clock: another kind of serial
process.
Receiving Pixels: just use a simple address counter (start with 0
at line start), incremented every camera clock cycle and store
the (4) pixels in several (FPGA internal) Block RAMs.
Transmitting Pixels: use a second address counter, depending on
SHIFT_COL starting with 0,1,2,... incremented every transmitting
cycle.
Ethernet: complexity depends on the underlying protocol, but a
std. frame can be stored in an additional BlockRAM(s).
Simple Example: a Xilinx Spartan XC3S200 or XC3S250E is big
enough wrt number of BlockRAMs, the receiver/transmitter logic
needs not more than 10% of all logic recources.
The only remaining problem can be the Ethernet Protocol, but a
simple UDP-Transmitter is not so complex.
Thank you very much. I will test your solution on Monday!!!
