Forum: µC & Digital Electronics Writing strings to the UART
von Andreas H. (ahoesch)
Hi all,
I am programming an ATMEGA2560 and am trying to send strings via UART0.
Sending single characters works,
void serial_writeChar0(unsigned char c)
   while ( !(UCSR0A & (1 << UDRE0)) );
   UDR0 = c;
but sending a complete string
void serial_writeString0(const char *s)
  while (*s)
      serial_writeChar0(*s);
      s++;
while (1)
   serial_writeChar0('A');
   serial_writeChar0('B');
   serial_writeChar0('C');
   serial_writeChar0('\n');
   serial_writeString0("Some String");
   delay_ms(500);
produces dirt on the terminal.
SÿÿÿÿÿÿÿÿÿÿÿABC
SÿÿÿÿÿÿÿÿÿÿÿABC
SÿÿÿÿÿÿÿÿÿÿÿABC
SÿÿÿÿÿÿÿÿÿÿÿABC
SÿÿÿÿÿÿÿÿÿÿÿABC
SÿÿÿÿÿÿÿÿÿÿÿABC
What the heck could be the problem?
Thanks a lot in advance!!
Andreas
: Edited by User
von stefanus (Guest)
Maybe the bitrate is not accurate enough. The R/C oscillator is not
recommended for serial ports and some combinations of bitrates and
chrystal also dont work stable. The datasheet contains tables with
recommended combinations.
Another problem cause might be not matching number of stop bits on the
two ends of the cable.
Instead of the while loop, I usually write:
loop_until_bit_is_set(UCSR0A, UDRE0);
I'm not usre if that makes any difference. Possibly not, but it's worth
to try.
von Mark R. (stevestrong)
It would be nice to see your timer settings clocking the UART0.
Quartz frequency? UART0 Baudrate?
What other tasks run in the background? Will the UART0 timer somehow
re-configured or used for something else?
