Forum: FPGA, VHDL & Verilog Upsampling of a received signal from UART
von Roger S. (roger237)
I have read in various literature books that the baud rate generator in
a UART module should generate a signal whose sampling frequency is
exactly 16 times the UART's designated baud rate.
For a 57600 baud rate, the sampling rate of the signal would therefore
be => 16 x 57600 => 921600 samples per second, am i right?
Given that I would then need to multiply this signal by a carrier wave
and then output it using a DAC (PMOD DA2) whose sampling rate is that of
1000000 samples per second, would I need to up-sample this signal ?
And now the question: WHY? In my RS232 code there is no specific
oversampling with a correlated rate, instead I simply wait a bit time to
read in the next bit value. Given that, I oversample a 57k6Bd signal
with e.g. 100MHz and thefore by a factor of nearly 1700...
Again: Why? What is it good for to multiply a more or less randomly
chosen internal signal with a carrier?
von Roger Swan (Guest)
I am multiplying the received signal with the carrier since i need to
modulate this signal for my project purpose. The question is, given that
i am going to pass the modulated signal through a dac whose sampling
rate is that of 1Msps would i have to upsample the signal received from
uart before i do the modulation part?
Do you have any idea how i would get to know the sampling rate of the
received signal from uart?
